SignUp Now!Installed my sway bar set with the help of Iceman, Superwerty and Blackcat here are my thoughts.
Pros:
Looks: Good construction and powdercoat. At first I was sad they only came in red bit now I am glad they are red. I love seeing them sparkle at me from in between the wheel spokes.
Size: Good Lawd they front sway is a beast! Pics do not really showcase was a brute the bar is. Rear while not as robust is still noticeably bigger.
Cons:
The rear sway is adjustable. Okay what does that mean? Use the first hole for a "soft" setting and the third hole for the "firmest".
Front bushings. I am not a big guy and don't have the capability of compressing those. Is that the best option Energy Suspension has? I cut a bit off flat side of each one but when installed they did not compress evenly at all. The top bushing was almost flat while the bottom barely compressed. Is that normal? Also what side of the bushing goes against the bar? Flat or the one with the lip? I used the stock ones while I researched.
Results:
Oh damn is it nice!! The second I took the first turn I thought "Damn this was money well spent!!". The truck leans so little in turns. IMO this is how the truck should have been from the factory. Merging onto the highway I could not believe how planted the truck felt. I can't wait until I get an alignment and can really play with it. Iceman, Jaeger and Blackcat thoughts echoed mine.
Sweet write up! Price please!
