only the sti not the regualr wrx they are 5-100
Just wanted to clarify that the 2005+ Sti had the 114.3 bolt pattern-->
The 02-05 WRX use 16x6.5 rims weighing 16.5 lbs with a 5x100 bolt pattern and +53 offset. The
tires are Bridgestone RE92 All Season Tires 205/55/16
The 06-07 WRX use 17x7 rims weighing 23.5 lbs with a 5x100 bolt pattern and +55 offset. The tires are Bridgestone RE92
All Season Tires 215/45/17
The 08 WRX and 09 GT use 17x7 rims weighing 23.5 lbs with a 5x100 bolt pattern and +55 offset. The tires are Bridgestone RE92 All Season Tires 205/50/17
The 09 WRX use 17x7 rims weighing 23.5 lbs with a 5x100 bolt pattern and +55 offset. The tires are Summer
Performance Tires 225/45/17
The 04 STi use 17x7.5 rims weighing 16 lbs with a 5x100 bolt pattern and a +53 offset. The tires are Bridgestone RE070
Summer Tires 225/45/17
The 05-07 STi use 17x8 rims weighing 19.2 lbs with a 5x114.3 bolt pattern and a +53 offset. The tires are Bridgestone RE070 Summer Tires 225/45/17
The 08-09 STi use 18x8.5 rims weighing 28 lbs with a 5x114.3 bolt pattern and a +55 offset. The tires are Dunlop SP Sport 600 Summer tires 245/40/18. Note they use 26" tires rather than all other WRX/STi models. When reading this FAQ, you will need to account for this (basically any place it says 25", use 26")
