SignUp Now!What sucks is I had a 4x4 oil pan assembly sitting around here collecting dust. I wish I knew it would fit on the truck.
I gave it away to a guy that got his smashed in when his diff brackets snapped 4 wheeling.
This Coupe oil pan idea is a very good one. I can't wait to get mine.
i take it that the baffle plate will be welded out fully or are you just going to have them welded in a few spots?
What if someone was to make a spacer ( 1") that would fit between the pan and the block like the intake spacer and the spacer for the oil pick-up. That would give more oil sitting in the pan
are all the spacers going to be welded to the pan like that or is this just the prototype?
Did you think of possible distortion when you welded the spacer to the pan. What if it was made of aluminium with a gasket on both side and a slit on the inside to slide in the oil gate that you fabricated,no welding involve and you just sell the kit ( pan spacer, oil pump spacer, longer bolts, 2 gates with trap doors and 2 gaskets). :hmmmm2:
When do you think you might offer it and how much are you thinking?
