What exactly does it do and how does it do it?
what im getting from it is it is able to get a more accurate reading and quicker reading from the maf back to the ecu thats about all i was kinda just looking for somthing that was going to be more stable under pressure than stock i posted the link above
found this:
How They Work: Mass air induction systems measure airflow with an electronic “hot-wire” type mass airflow sensor. The sensing element in the air intake provides an output voltage reading that is directly proportional to the amount of air that is entering the engine. This airflow measurement reduces the calculations required to control fuel and ignition spark advance. Mass airflow sensors can react quickly and accurately to sudden changes in airflow while improving overall vehicle performance and drivability.
Calibrated for Optimum Performance: Granatelli Motor Sports spends hundreds of hours testing and calibrating to optimize performance for your specific
application. Each application is calibrated on our proprietary computerized flow bench. Then, each application is dyno tested and driven under a variety of real world tests using sophisticated air/fuel ratio monitors, exhaust gas temperature gauges and
data logging computers. The result is optimum performance for YOUR specific application
