Calling all transmission issues on Xrunner
meanx
Well now my transmission is Jamed in gear,I took it apart thought I had it fixed so I put it back together was shifting it and it Jamed in gear so now I'm gone to take it somewhere and let them fix it, has anybody ever had any luck on getting there transmission rebuilt?
gearhead899
I wish rebuilding these trannys would fix them but iv come to the conclusion that they will never be great. my 1st xrunner I got used with 50k or so on it. you couldn't rush the 1-2 shift or it would grind and you would have to take it out of 2nd and put it back in (cost me many good runs at the track) and also 5th would grind at higher rpms but seemed to smooth out after I switched to redline fluid. my current truck I bought brand new and you still cant rush the 1-2 shift. I really wish these things had a cheaper trans swap option cuz id do it in a second. my other cars I can bang shifts super fast without a problem but not these trucks. I really feel like that contributes to not being able to get these things to go real quik in the 1/4 mile too :thumbdown:
SGTPT
Mine grinds in second gear. My TO bearing is screaming time to replace.
rennurx
My trans was rebuilt and it cost more then buying a new one.. someone needs to come out with a rebuild kit. Or a t56 swap kit that you can actually go on a web site and click "buy it now". And then I would be happy.. I don't see my trans lasting too much longer being boosted. Since I'm already on number three and I was n/a
TommyXrunner
http://www.manualtransmissionpart.com/RA60.html
TommyXrunner
Guess I should have been more specific.
you can also buy rebuilt trannies for around $1500 on ebay. new is about $3000 i think. i'm scared my trannies gonna die one day and i won't know what to do. rebuild the same crappy tranny and get another 5 or so years out of it or spend some serious $$$$ and swap. i think someone needs to make a new (much improved) tranny for our trucks that just simply bolts on for $3000
meanx
I found a company that does only standard trans. they have a rebuilt tran. with a 2 year warranty unlimited mileage for $1475 that's the best deal I've found yet. www.Manual-transmission.com ,in Tallahassee Florida.
TommyXrunner
I found a company that does only standard trans. they have a rebuilt tran. with a 2 year warranty unlimited mileage for $1475 that's the best deal I've found yet .Manual-transmission.com,in Tallahassee Florida.
nice find man!
Brianburkhart1
Mine had developed the bump and then the other day it blew third gear also noticed that it was getting hard to put into 1st and reverse. Trans shop said they can fix it.
MaxRun
Hello, I'm thinking of buying an x-runner but now I'm concern about these reports of problems with the 6-speed. Has Toyota ever admitted or address the problem? Did they make changes to newer models? Thanks!
No. I took mine in for a transmission problem while it was under warranty and they refused to do anything about it and then charged me for their time. And they still use those junk transmissions in the new models.
The truck is fun as hell, but the transmission ruins it. The best thing you can do is try to get one for a really good price and keep a couple thousand saved up to put a t56 trans in it.
Red-XR-Pride
My tranny went Full Slop. even needed a New Core when i went to get it Rebuilt. I went to "The Truck Shop" in Miramar California. He got me a new Core and rebuilt for 900$ i havent had a single problem like i had with the way the tranny was from the factory. and its went thru boost and now its just N/A but i flat foot shift anytime im racing or trying to have some fun. so i assure you the tranny gets plenty of abuse. and it works perfect. if anyone is gonna have it rebuilt id send it there.
Deathoftheparty
No. I took mine in for a transmission problem while it was under warranty and they refused to do anything about it and then charged me for their time. And they still use those junk transmissions in the new models. The truck is fun as hell, but the transmission ruins it. The best thing you can do is try to get one for a really good price and keep a couple thousand saved up to put a t56 trans in it.
Is it the T56 magnum that everyone swaps in?
Not everyone, but a couple people have. I believe Coupe and Torspd both have the t56 magnums.
I have a T56 magnum, which is slightly different from the T56.
so whats the solution here ? replace or rebuild ?
To rebuild is the cheaper route, but you may have the problem return.
The T56 is a good mod, but it is expensive.
Gearbound
in the r150f and r150 and r154 marlin crawler recommends redline MT90 and this has been proven true. is this the same with the ay6?
my roommate has a 2014 and since day one at 9 miles on the ODO 2nd has been knotchy and not smooth. mine is a 2014 and shifts like butter.
