DoubllD's Juggernaut Build
Doublld
Lol needy jk that is gadgets old engine. The fan is from ffdynamics also I had it on the dyno lost oil pressure an it's at darton right now it had almost 400whp an wasn't half way through the session yet.
Doublld
Had a freak thing happen the plug for the oil galley popped after right after I completed my whole build number 6 bearing got hurt need a new crank but everything else is fine so hopefully after a week or 2 should be back on the dyno here is a pic
Long long ago. In a galaxy far far away.....:crinklehair:
As far as I know, it all started here. >>> http://www.xr-underground.com/vb3/showthread.php?t=50731
The custom intake manifold made by a friend of a friend of mine, here in town. Was originally going to be tested on Toon's truck, but his was in the shop gettting tuned. Was instead tested on 1GRracer's for fitment, but didn't fit. Little did we realize that it didn't fit because his hood is different than that of the Tacoma. Time past, and DoubllD picked it up as he wanted it regardless. Wouldn't you know, it fits the Tacoma perfectly.
I remember Gabe, the fabricator, getting it flow benched. He told me that it flowed as well as an aftermarket intake manifold for an LS1 or LS2. So it moves some air. :giggity:
Then, a few months past, and he picked up the 1st Darton MID sleeved engine from Gadget.
Made a table out of his old engine.
Doublld
There is no before or after at this moment I will have a after soon. Also here is more pics
Redlantern
Lmao. Where did this come from all of a sudden? Great start to a thread!
Can XR
Wow now thats a build ! I totally forgot about that intake manifold. Glad it found a home and is being put to use.
Sweetness.. man there's gonna be a lot of us on here with built engines now... Look forward to how it ride n puts down the power..
hottacoX
Welcome and nice project!! Certainly scored a deal on that motor.... care to share more on the bearing pic? Looks terrible!!
I love the table idear!! I hope to do the same soon!!
Doublld
Well the whole setup was running as of last Saturday an I was on the dyno doin pulls then all of a sudden no oil pressure found the oil galley plug had popped out so took it 2 darton an they told me I needed a new crank. Number six was the only bearing Hurt it didn't spin an no noise so the rest of the engine is fine. Also the pic of the bearing is what happened 2 my stock engine that's why this entire build has come about lol. When I get all the bearings and crank back from darton I'm gonna assemble out everything back in an then make a custom front mount and get back on the dyno. The last pull before all the madness happened I was at 10psi and had 385 whp
hottacoX
Yeah that sucks, I feel your pain.....
My motor wasn't pulling oil to the top while cranking, I intent to mention this issue to Paul at Dezod!
X-roller
You should never crank an engine that far to begin with when its dry. An engines oil pump has to spin pretty fast to fully fill the system with oil. The only thing i would have them do is look those cams over because no assembly lube plus no oil and cranking.... i dont even want to think about it...:ahhhhh:
Doublld
I agree I had assembly lube oil an Vaseline in the pump 2 create pressure. The snail is a 67mm
This has been a common issue with these engines after a teardown rebuild... Hope I dont these problems....
hottacoX
I hear ya but keep in mind I payed for a complete long block that shouldn't have run into any issues... And should have been ready to fire....
I am not looking forwar to what dezod finds
DoubleD any idea on time fram for you to get her up and running again?
Doublld
Well as soon as I get a crank an bearings maybe 3 days after that
Not mine. :D Just should have torn this one apart to clean it when I got it. I will be much more thorough on all future similarities.
