SignUp Now!Just go with one of the urd stage 3 or 3+ clutches. 3+ would be a little overkill for you though but it would still be fine. I had a Competition Clutch stage 3 in my truck and it was a good clutch too but I hear good things about the urd ones. You won't need anything over stage 3 unless you're gonna build your engine. I'd also look at the lightweight flywheels from urd. I had one of those too and I'd recommend it as well. They have bundles with the clutches and flywheels together. The only negative is that they look so damn nice you hate to hide it inside the transmission lol
How is your clutch pedal feel? Cause my friend has the Urd clutch and said its a leg work out. Thanks for your input!
I don't have my truck anymore but the CC stage 3 clutch felt surprisingly like stock. I honestly couldn't tell any difference in pedal effort. The urd ones I'm not sure of, but they're probably not far off of stock feel either. They may be a tiny bit stiffer because I believe they hold a little more power vs the same stage of another brand.
There's also the twin disc from urd which is the best of the best but that may be out of your price range. Keep in mind it comes with a new (I believe lightweight) flywheel as well.
