sdxrunner619
- Jan 20, 2010
- 3,836
- 7
Anyone ever done a 2jz swap?
This question comes up once a week on the various fb pages. Nobody has on a 2nd gen taco.
SignUp Now!Anyone ever done a 2jz swap?
Sure there has. Jaxchrisfla posted it up years ago. 4x4 with 2jz swap. Machined the OEM transmission then welded on an adapter to mate to the engine. 6 - 1 header into the turbo.
Actually there is one with a 2jz. It's in Dubai.
Here's a post on ig. https://instagram.com/p/5y8mXbEken/
are they what OP is looking for, and do they increase power, and how hard is install?Those are from www.webcamshafts.com Re-sold and marked up.
how long and how much for a shop you think?Yes that's them. The instal would be quite extensive. It would be easier to pull the motor then to try and do it in the truck. It really is not a mod that many people have done due to the cost and labour required.
I still have a set of webcams if anyone wants them.
Setup for n/a or supercharger. Not turbo.
I could do it in the engine bay. Would have to pull the timing cover. Not the easiest cam installation. Would have to check valve lash and replace the buckets where needed. Then it'd be good to go.
