Calling all transmission issues on Xrunner
Hmm seems odd. Maybe one of the auto trans guys could help I would try a thread on it and see what they say.
Redlantern
It doesn't bother me unless it's about to blow up....then I might need to do something
The delayed shift from 4th to 5th is of the norm. Some times it takes way too long. Doubld has also experience this in his auto. If I remember correctly the guy at level ten said the valve body upgrade will eliminate majority of the symptoms u described. Let me check my emails.
How hard is that install?
Redlantern
If you send in your unit, Not that hard. It's just messy cause trans fluid will drop all over your face. IPT has a video on their website of how to do the install. On the other hand if you do the DIY route with the level ten kit, I'm not sure how hard it is. By the looks of the other thread we spoke in, it looks fairly easy to do.
how expensive? I am trying to consider what all to do... not sure how much money ill have to mod, so trying to make a list
tcook08xrunner
I have 08 xrunner with 120000 miles I've never had any grinding changing gears but when I shift from idle to first I get a clunk noice it's only from idle to 1st or reverse to 1st but never idle to reverse
Hector Gonzalez
Hi all, Just did a clutch replacement, ordered clutch from the dealer did the install and replaced tranny fluid, have 2 new problems did not have before.
#1. 3rd gear grind when shifting at high rpms ( feels like syncrho but wasent there before).
#2 When riding in 2, 4, or 6. gear there is a hissing sound coming from the tranny right below the shifter, goes away when i disengage clutch,
Any thoughts??
I used factory fluid on tranny and had flywheel corrected.
150k miles bone stock.........
Any thoughts??
@o0opackersfano0o, any thoughts?
mejbro
Welcome to the Underground Hector!
Most of us have had better luck with MT-90 for fluid, but as long as you put 2 quarts of something Toyota in there you should be fine.
Don't forget to adjust your clutch pedal, that may the reason for your hiss.
There's a thread somewhere on here about it, also there may be a break-in period for your clutch so slow down lol
Hector Gonzalez
Thanks mejbro looking forward to doing the MT-90
Adjusting the pedal i seem to have too much top play. Hissing only happening in 2, 4, 6 though all the gears that happen to take the shifter down(not sure if this indicates something) what was once just a worn clutch is turning into a headache !!!!!
Hector Gonzalez
So i just completed the oil change with redline i ordered from amazon.
Let me just begin by saying im a BELIEVER now lol.
Warmed it up did some cruising them ran 3 hard passes and what i noticed is the gears go in firm no clunks or clanks like before.
3rd gear grind is GONE!!!!!!
Im a happy camper now to break in the new clutch.
Thanks fam much appreciated.
I've run it in mine for nearly 200,000 miles. I'll never put anything else in it.
