Limitless
- Feb 23, 2010
- 386
- 12
Finally finished my little side project that i started earlier this year. Thanks to a friend I was able to pick up some of the of the Xtreme Kreations door panels to replace the giant 12" sub and enclosure I had. Got a new JL Audio XD600 Amp for the Subs to match the JL amp I already had for the speakers. Subs are JL 10W1V3 and the speakers are JL C2-650X.
The person who had the panels also had an extra set of rear door panels so i was able to chop them up without effecting my stock panels.
Cut the hole for the sub and speaker as well as the MDF mounting rings. I cut a slit into the Sub mounting ring so i was able to spin it in like a screw.
Drilled the holes for the speaker mounting and used Tee Nuts on the back side. I had some bad experience cracking MDF with screws in the past so I figured I would just use Tee Nuts and bolts to prevent that and get a snug grip.
Was going to try and make the panels grey to match the interior but could not find a matching shade and it just didnt look right. So i picked up black wrinkle coat paint and think it turned out great. Decided to paint some red accents on he speakers while I was at it to make them pop a little.
Took the stock panels off the truck and had to make the steel opening larger by rougly an inch in all directions to fit the new sub box. Just used a jig saw and some steel bits and it seemed to work fine. I used the mounting holes as reference and measured to draw the actual hole I needed to cut. Filed and painted the cut edges to prevent rust.
Got some damper from SecondSkinAudio that turned out to be great and easy to work with. I put the stuff everywhere since i heard that these panels can rattle, and topped it off with the 1/2" damning foam sheet. While I was at it add added more grease to the door handle mechanism to prevent metal on metal vibrations.
Ran new wire (10gauge for sub, 12 for speaker) through the grommits to access the doors cleanly, and ran to both amps.
Put everything back together and off we go. Had these on for three days now and wow does this setup sound good. I havnt cranked it up enough to shake the whole truck but from what i can tell there doesnt seem to be any bad vibrations or rattles. I have spare damper so i will attack these if they come up. WAY better then my previous setup with a single 12" sub. I can actually feel the double bass again.
