SignUp Now!Yes correct, and I verified from rock auto site that they have different part numbers. Albeit just a one digit difference.Makes me curious to know if there is a difference in outputs between the two? Denso manufactures both correct?
My block, crank shaft and heads are all done and ready for assembly. Tomorrow I'll pick them up from the machinist.
I was told by a friend that installing the ignition coils from the later model dual VVTI 1GR motor improves performance. Anyone heard of that or tried it?
That's probably due to the stroker crank. I have no clearance issues with the oil squirters at all.Getting close now! Looks truly sharp.
I have had the similar issue with the studs many times. Freaks me out every time.
Which brand rods are those?
With my stroker crank and my Carrillo H-beam rods, I had clearance issues between all of my oil squirters. That took quite a bit adjusting and testing to make sure they all cleared with room.
