SignUp Now!Not going to work. The old one wasn't doing anything at all. It's bad.So you bought a new supercharger......does that mean you still have the old one? Any thoughts of trying the old one with the new filter?
Looks good but is bad. Weird.Not going to work. The old one wasn't doing anything at all. It's bad.
The MAF is only used for Intake Air Temperature reading, nothing else. I'm using a MAP sensor, with MAF elimination mode.Man, that is one overly complex ducting setup. I have no idea how that MAF sensor is getting a good and proper reading on a 90 degree bend like that.
Oh, I can't do a burn-out, this truck is permanent 4WD. Unless I remove the front drive shaft. Or modify my transfer case as many people do around here.Australian for burnouts.
Big chain strapped to something to hold you in place. 4wd burnouts!!Oh, I can't do a burn-out, this truck is permanent 4WD. Unless I remove the front drive shaft. Or modify my transfer case as many people do around here.
Man I still love my truck, believe me.Big chain strapped to something to hold you in place. 4wd burnouts!!
