WANTED Xii DROP SPRINGS
TACOWHEELS
I'm looking for some Xii Eibach drop springs if somebody has a set for sale.-thanks.
AZ Sun Lover
Have you thought about Tundra racing / SOS front 1.5" drop kit? You just got to make sure you clearance / alien the alloy drop spacer from the UCA. That's what I have now until I get the QA1 coilovers mounted.
Being XII has closed the doors!
AZ
TACOWHEELS
AZ
I will check them out. I just need to know if there kit will work with my DJM calmax drop kit. Also I called Eibach and gave them the part # stamped on the drop springs xii was using and they said they have them in stock for purchase. I questioned whether these were "specially" produced for Xii and it sounds like these are an off the shelf item from Eibach they were using and presenting as there own exclusive product. If anybody's interested I can post the Eiback part #'s for them along with a image of the Xii kit that shows the same part #'s.
Please do I’m looking to get some replacements. So I may go that route if I can
AZ Sun Lover
That sounds like par for XII!
Sorry guys I have never thought anything about XII. I bet if someone digs good enough you can most likely find all their parts as off the shelf from another vendor. If you have their custom ( cough cough ) swaybar numbers I bet Eibach or Addco might have them!
TACOWHEELS
So this is what I found on my research on the matching Eibach part # Xii is using would be #1400.250.0500S . The spring rating code on them is Y/Y SS950TXR . I have attached a picture of the Xii kit showing the springs they use that was pulled of a x-runner. I'm sure if you contact Eibach they can confirm this for you before purchasing.
Arcenik
I don't think thats right, if you break down the part number it would be
1400 = 14" spring
250 = 2.5" diameter
500 = 500lbs spring rate
s = silver
