Gators Taco
<a . href="http://www.xr-underground.com/forum/sho
- Jul 27, 2010
- 1,785
- 24
For over 4 years the X never took a spoon full of oil. We had an extremely cold winter. Used 0W30 for all that time. I would check the oil level one a month and no changes. Only 90000 km on the X. Drove the X once a week and decided to check the oil and it was 3 quarts low on only 7000.km since the last oil change and may be 1500 km since the last check. Check compression and got 205 to 210 psi on all 6. Plugs were black, same as the exhaust and the O2s. Scope the piston, same, black deposit. The idle is at 700 rpm and good throttle respond. Valve guides or oil ring ????? :hmmmm2:
