I should be able to begin installing the turbo very soon here. But I had a few questions.
I was told that the oil return line is being routed to the timing cover on our trucks? I thought it goes back to the oil pan? Is this to avoid pulling the oil pan? If I do go to the cover, where is the best place to land it?
I see a small metal plate on the front cover that looks like it may come off and could be the perfect place for it?
Does anyone have pics of this on a timing cover?
The oil supply line comes from the location under the oil filter? If so what size and type fitting or adapter is needed there? I tried searching and didn't come up with this information.
Thank you all for your help with this....:top:
