Bought Another Car Today!
BlackXrunner05
I bought this from a 17 year old who would prefer a honda instead... it has approximately 191K miles on it.... a 1996 Toyota Celica GT 5spd!
BlackXrunner05
It will be! Right now it has a lot of things that need to be fixed or removed lol
BlackXrunner05
There is this module that seems to be piggybacked into everything.... I'm not sure what it is, but it hangs under the driver's side console ...
STONER-X
Look for any part numbers or a brand on it and Google it
BSP06XRU
Old Member
Nice... new projects are fun! :top:
Keep us posted!
BlackXrunner05
What happens when I turn on my High Beams the passenger low beam turns off and the inner high beam light never turns on. Any ideas?
HAMHAWK_JAY
If i remember right from my 6gc days the trans should bolt right up. I had the same problem with my lights till i replaced the battery but i did not have hid's so its probably not the same
BlackXrunner05
They're not HIDS... so I'm not sure what is going on
BSP06XRU
Old Member
Glad it was a quick, easy, and cheap fix! :top:
BlackXrunner05
Yeah me too... but then the passenger window motor went bad and I'm not sure what broke, so I'm replacing the motor. Hopefully that fixes it???.... But to make matters worse it won't start now. It cranks and cranks but never ignites.... Not sure whats going on... Could be plug wires, plugs.... I removed them today, to check for spark. When I put it all back together, it turn over after... then i turned off the car and tried to restart but nada ...:hmmmm2:
markgt531
I'm thinking about it lol..... I wonder if it bolts right up to my 5 speed trans?
agree!!! I Owned one for about a month it was my friends 3sgte/5speed swap .. i have his e153 trans rebuild that he was goin to use to upgrade from his stock trans. im selling it if you interested lol its just taking up space and i gave up looking for either an mr2 sw20 that needs a trans i can put this thing on lol
BlackXrunner05
But to get it to work in a Celica GT you need a set of GT4 ST205 shifter cables FYI
