P0037
Just pulled a P0037 code. Truck has 178k miles. Would it make sense that the front WRAFs would go at this mileage/age?
Anyone? I cleared it yesterday and it's back today.
o0opackersfano0o
its the pass side bank o2 sensor. just the heater circuit. u can ohm out the o2 sensor. most likely will just need replacing.
Slywhitty
"Midget Magnet"
Those are your original wraf sensors??
Man you got lucky. I've been through like 4 of them over the years lol
So it's the rear sensor? In the Y, not the front in the header?
Redlantern
Yep looks like that's the one.
So I swapped in brand new rear O2 sensors in both banks, code came back this afternoon...next?
Assuming that you're only getting the code for the passenger side, correct? If so, that rules out swapped wires.
Since no cats, do you have an O2 sim? If so, how old is it?
Try unplugging it from that side and see if that code goes away, and is replaced by just the missing cat code. Or both sides, to have all things equal.
I was talking with @o0opackersfano0o offline and he made the same suggestion. I'll pull the O2 sim and see what I get. But to answer your question, yes, just a passenger side code. And the O2 sim is about 4 maybe 5 yrs old.
