C10Ben
- May 8, 2017
- 32
- 3
Hello . Just bought my 08 x runner two weeks ago . 108k miles . Had check engine light when purchased. Was told just an 02 sensor (a lie , but no big deal bought it for the body )
Well it wasn't an 02 sensor . Had random multiple cylinder misfire . Then isolated cylinders 2-4-6 ..... reading rich one bank . Lean the other bank ....
My first though was fuel injectors .... replaced the whole drivers side bank ...... put new coil packs and plugs .... still getting the random multiple. Every now and then . But I can clear the code and it runs fine ...... this leads me to believe it's the vvt gear ( been through this before ) .... so long story short is...... does anyone have a part number for the exact. Vvt gear ? I've found a few but They look
Like they are for the fj cruiser
Or highlander. I have the duel vvt-I
1gr-fe. I believe the one I found will work and its oem Toyota .... here is a link if anyone can tell me for sure . Def looks like the one . I only ask because I had read something about the x runner. Being excluded from. Compatability. But i would think a duel vvt 1gr-fe. Would be same regardless of car it's in .....
I believe. I'll be ok with this ...
http://www.m.ebay.com/itm/182325117117?ssPageName=STRK:MEBIDX:IT&fromMakeTrack=true
