radracer_x
- Nov 17, 2016
- 72
- 9
Before I bought my truck a year and half ago, I read some where on how to mod your clutch petal for better transfer. Anyone about this or has done it? Much thanks.
SignUp Now!With the throwout bearing issues of this truck I would advise against this mod.
I don't see this as a good idea if adjusted wroung and the barring is going to go as the clutch wares this will become an issueIt's been on several trucks for many years...if the bearing is going to go, it's going to go, IMO
I drove around today riding the clutch tell i felt that the free play was to little and from what i gather it's not much for me to even care about plus you kinda want free play further more with eh amonte of shitty toyota lag in the gas pedal it's kinda point less, mix this with a fast shift frist to secound still going to buck like the little bitch the tacomas shitty laggy throttle is
toyota did this on purpose to slow down your shifting, I had to teach my self how to shift the x runner coming from cable driven cars this was down right so annoying
main point doing is trying to make the clutch faster when ever thing is so slow to responded, this is one main reason I have yet to build a short shifter for this truck( have the nylone to do it but it's not going to magically make the truck better just more of hand feel, since I like soild shafts and to feel the gate moreThat's why you need to adjust it properly.....there are a lot of mods that can be detrimental if done wrong.....if adjusted properly this just lowers the pedal and still provides complete engage/disengage functionality.
I am pretty sure short throw shifters and Sprint Boosters are available to cure your other shifting complaints....if you know where to shop ;-)
If you choose to do this mod, just check that it is adjusted properly afterwards. 2 ways are Coupe's method of checking that the fluid fills the reservoir completely or ensure piston is at the top of it's travel with the pedal released. Many owner's including myself have done this mod with years of driving and no bad results. As with every mod you want to gather information, understand the results, determine your needs and perform properly.
it doesn't fix shit the pedal has lag from the factory you have to change the codeing to fix this some cars are just so horrible then ya mix it with an auto and take for ever to think on how it wants to work (caugh) any thing built by hyudai most numb gas pedal everI am pretty sure short throw shifters and Sprint Boosters are available to cure your other shifting complaints....if you know where to shop ;-)
