ToyotaNewbie97
- Mar 25, 2015
- 89
- 14
Any updates as to how they are holding up?
SignUp Now!Those are the xii mounts they will give you about 3/8 more drop. I outlined the mod that would need to be done when ordering from slick and dirty to get the additional 3/8 drop.Arcenik,
Did you see these upper mounts? I bet you get over an 1.5" more drop!
Remember the mounting point on the shock is inboard of the hub face. They also look like be easier to make.
http://www.xr-underground.com/threads/xmplry-2015-trd-supercharged.57686/page-7#post-991833
You are correct that the mount sits offset from the lower mount but the shock is only sitting at a 15 degree angle which is not much. The xii mounts don't sit much higher than the ones that could be ordered from slick and dirty. The fact is you cannot move the mount up much, as you will eventually hit the shock tower base plate with the shock as the shocks needs a 1/2in clearance from the center of eyelet to shock mount plate. You are also correct that moving the shock up 3/8 will net you more that 3/8 of an inch drop. But the difference is negligible 1/8". The diagram below shows 1/2 movement in the shock mount will net you 3/4 at the wheel. You could pay someone to copy the xii mounts if you are looking for the extra 3/16 of an inch or you could order from slick and dirty with the adjusted top mount hole moved 3/8" and net 9/16" lower at the wheel than the original designed bracket.Sir,
With the most updo respect! I for one totally respected and praised your work on this
But I will have to disagree with your assumption of the amount of drop that XII top mount will get.
The bolt that goes through the eyelet on the shock is the width of the tubing from the top plate. Yours is approx 3/4" from the top plate. Plus please remember the shock mount is inboard of the hub face. I'm not an engineer and just totally guessing if you get 5/8" at the shock mount will get more drop at the hub maybe up to 3/4" or more?...
Is there anyway you could have your buddies make the top shock mount like the XII? Just asking!
Again Thanks!
AZ
Sorry,
Not trying to start anything just thought it would easier to weld two small dia. pieces of pipe and clearance the top round mounting plate.
As I read earlier that you were thinking about running the shock so the shock adjuster is at the top. That's what I would like myself!
I really do appreciate all your leg work. Another thing I don't like about XII coilovers is they are on heim joints. Don't know if you been in a street car / truck with heim joints on the street but it's ungodly noisy! Gets real old real fastWe also had a light weight sand rail when I was many years younger and it ran on heim joints. ( I would drive on the streets when my father would let me ) We were always replacing them because there is no real way to lube them. They are constantly moving thus wearing out.
Oh, if your are ever in the Valley ( i.e. Barrett-Jackson or something ) please look me up as I owe you an adult beverage.
AZ
Well Just A Little Update From XII On Their Coilover's.
I text XII and finally got a reply last night. I'm 99% sure it was the lady of the company. I asked when they would be selling their coilover's again. They text that the gentleman who was building their upper mounts and brake line mounts had passed away. So they were is looking for the "best of the best" "local to them" to build their mounts again and that they had other pressing issues to take care of first. I texted them I was sorry to hear that but, if they couldn't do something right away could I have the drawings for the mounts. To put it nicely that's when the texts started getting a little hmm... a short! Long story short I had to ask them to stop. I ended up having to block the number
Yes I know they have two businesses but they shouldn't just blow off XII customers. They are Not McDonald's and they are Not selling the McRib.
Just my.02 cents.
You asked for their drawings? Did you really think they'd just hand you the plans for their mounts? They worked on those for a long time, testing them at track days, breaking them and redesigning them. No smart business person would just give away their plans .
I am going to look into having some new upper plates made to maximize the drop for the qa1 coilovers. The design would be similar to the XII ones.
Would people be interested in these?
I don't want to waste my time, hopefully the price would be around the same as the slick and dirty one.
