super charger on the way does anyone have any good maps for the arp x1
Nashman
Well I bought a magnauson super charger and was hopping some people had some maps that they would like to share
specs
equal legth header
equal legth y pipe
no kitty cats
2.5 inch exhuast
volante intake
arp x1
Amo-cat3
specs
equal legth header
equal legth y pipe
no kitty cats
2.5 inch exhuast
volante intake
arp x1
i'm set up almost like you except i have the 2.7 pulley and and 7th injector also no cats. It's a hot map and not sure how to copy it off of the x1 as I don't have the map stored anywhere on my computer. I don't have xtune set up on my laptop so not sure if I can set up xtune then hook up to my truck and copy the map. If you know how I can do this i would send you my map.
Amo-cat3
I've uploaded this file I got from APR a couple years ago. This is a hot map for no cats. hope this helps
  • Tta40.03A.F_425.Installer.zip
Be careful just swapping out tunes if you don't know the exact setup it was created for
Amo-cat3
I've been running this map for years now and my a/f seem spot on with my setup. I don't race or run my truck too hard plus it's an automatic. Ocassional towing max 4000 lbs. It's set up for the 7th injector and I don't even know if it's ever been activated lol.
Nashman
ya will this sucks i have tried every map in my truck all of them are junk
I am using a usb stick since the lap top is having issues with drivers
so as the book says you put the X1tta... blaa blaa then ya stick the stick in and it will upload the map
ps that map ya posted int he same map as the ones on there web site
Nashman
well figured out whats going on it's fuel dumping bad and shooting out a code on every map i have tried drive around fine hit the skinney pedale fuel dumps
Nashman
well it fixed now truns out useing the usb stick to update didn't work out well. used the laptop and worked just fine
i am on the f2 map right now and i have abit of spark knock when in high gear with low rpm
is this normal for this tune ?
