- Nov 8, 2007
- 3,149
- 10
I just removed and disassembled my sub. First let me say the removal of the cover was a PITA!
Here goes:
See the little pink clips in the pic? those are what you have to fight off
First grab the bottom mount (RED BOX)cover on both sides and pull, this one is easy
Next grab the each side of the bottom of the cover (BLUE BOXES) pull until you feel the clips pop out
Now grab the passenger side and top (GREEN BOXES) This is the real hard one, you gotta tug on these pretty hard, when you are pulling the middle you need to pull towards the front of the truck and out to the passenger side.
You should be able to grab the driver side and top (YELLOW BOXES) and the rest of the cover should come off completely
There are 4 10mm bolts holding the assembly to the rear wall, they should be easily visible without the cover on, and don't forget the wire harness plugged into the bottom.
To disassemble the enclosure after it has been removed you need a torx T20 and T15, #2 Phillips, and a small Flathead
Its a sealed enclosure with a 6in sub-
There are 3 LED's you will notice with the cover off, they can be pried out of their clips and this is a pic of the in various states of disassembley
Here is the inside of the amp (just cause i like to take things apart:biggrin
There are holes that would need to be covered. (sorry its side ways i cant figure out how to turn it lol)
The pics are from a cameraphone so sorry if they arent that great. Any questions let me know:top:
Here goes:
