last few hundred feet huh? go back at look at the link he posted with the fastest times
Gadgets MK3 has the best 60ft time...better than my trd 4x4. Then check out the rest of his slip. The URD blower is trapping the same mph at the 1/8 as ntinhri's TRD, etc etc. The MK3 makes plenty of low end power. Roots blowers do not dominate at the line
A roll race on the street the TRD will get the hit for about 1 second and the URD will row right past you
Any TRD unit can throw on spray (A trd blower an average nitrous setup will be lower then the cost of any FI kit out there - somewhere around 4500$ with some supporting mods) and then no one will be 'rowing past you'. Further more this method nets you a better power curve, way more power potential, and your only using it when you need it so its less strain overall on all the fragile stock components. A nitrous application lends itself PERFECTLY to a TRD blower; not so much a truck running a N/A dry manifold.
If you want to compare again 60-100 in accel video threads.
Wallasx: 5.5 seconds
My time: 4.9 Seconds
Someone would get spanked in that race and it wouldn't be me; it can easily be done. But wait a second... My dyno was only 415 HP and his was 450 HP (or close at one point) how could that be?! -> Power Curve
This is a really old argument; URD is great on the mid to top end (they are peak power monsters).
TRD is a low end to midrange monster
Both are good kits, some will prefer one - some the other and both have their advantages with mods you can do outside of the actual kit.
Why does the URD have a better 60' then you in 4x4 werty?
Lets see.... TRACTION!!!!
Maybe because the lack of low end TQ and some half decent tires = better 60' traction then a TRD truck even in 4 wheel drive. :laugh:
THAT WOULD BE MY GUESS BUD!
/Burn
