4x4 rear leafs
Discussion in 'Suspension' started by o0opackersfano0o, Aug 10, 2016.
  1. o0opackersfano0o
    Jun 23, 2016
    374
    73
    Been searching around the forum about lowering the x with 4x4 rear leafs. Just wondering who has actually done it and how much it lowered it. Some people say 2"/1"/.25". I was thinking about trying them out and maybe removing a leaf as well. Just want everyone's opinion. Thanks.
  2. AZ Sun Lover
    AZ Sun Lover Member
    Jan 13, 2013
    167
    Newer Pre-runners & 4x4's have a new 3 leafs plus and over load spring and or 4 leaf packs. The newer 4 leaf packs are stiffer then the older 3 leaf packs and just a bit stiffer then X-runner 3 leaf packs. Per my butt Dyno but my butt Dyno is way over the hill. I have 2014 4x4 rear leafs on mine. The amount of drop changes from truck to truck because the older springs will sag over time & mileage.
    I got right at 2" of drop from the stock extra cab rear springs. X-runners will get right at an 1" of drop.
    AZ
  3. fishsticks
    fishsticks Because fast lifted truck.
    Nov 29, 2015
    207
    6
    In my experience, the main leaf of every used 4x4 rear pack I've seen is bent at least slightly right behind the front eye. There's a reason there was a recall on them. I wouldn't put those on my truck.
  4. o0opackersfano0o
    Jun 23, 2016
    374
    73
    I work for toyota and we have just been tossing all the old leafs from the recall. And some are even really new. I'm gonna wait on a newer set to come through or a set with no rust and do some experimenting with them.
  5. whippersnapper02
    Nov 16, 2010
    394
    18
    I'd invest in quality stuff over the OEM junk.
  6. AZ Sun Lover
    AZ Sun Lover Member
    Jan 13, 2013
    167
    Hmm,
    I would be interested in a set of newer 3 leafs. But the shipping might kill any deal.
    Our truck rides pretty damn stiff and we have a metal tool cross box mounted in the bed. We use it to mount our MTB's and to toss in muddy riding gear. Also carries the truck cover.
    AZ
  7. Clunkydiamond
    Clunkydiamond New Member
    Aug 21, 2016
    6
    I have some questions about this, not to hijack your thread, but why would a 4x4 leaf lower our trucks? And would it also raise our load capacity? I want lower the truck but my rear leafs feel very loose me at 180lbs and a friend at 200lbs can jump on it and hit the bump stops at stock height
  8. blackx-runner
    blackx-runner "White Flash"
    7,580
    13
    I think what happens is 4x4 leafs don't have as much of an arch to them. On 4x4 trucks the axle is mounted underneath the leafs so that is why the trucks sit higher. When you use the flatter 4x4 leaf springs and mount the axle above them you end up with a little bit of a drop.
  9. AZ Sun Lover
    AZ Sun Lover Member
    Jan 13, 2013
    167
    Well said!
    AZ
  10. Clunkydiamond
    Aug 21, 2016
    6
    Gotcha, but will the 4x4 leafs also help with load capacity?
  11. imom
    imom Member
    Mar 24, 2015
    39
    Anyone else use the 4 leaf packs? Curious the outcome on regular cabs.
  12. MaK10-XRnR
    MaK10-XRnR Member
    Apr 13, 2017
    65
    6
    I have a set of 4wd springs that have been sitting in my garage for years now. When removed from the original truck to replace with OME lift springs, they only had about 12k miles. Is there an actual benefit to these over my 62k mile stock X-runner springs? What exactly does swapping in 4wd springs do?
