70mm vs 76mm throttle body upgrade
Discussion in 'N/A Mods & Tuning' started by TacoRojo, May 26, 2017.
  1. TacoRojo
    TacoRojo New Member
    Apr 6, 2017
    6
    I've been reading a lot of the threads about the URD throttle body adapter. Most of the information about the adapters is about the 76mm one. I haven't seen much about the 70mm. I am seriously considering the upgrade, but the whole idle problem that occurs concerns me. Is the problem the same with the 70mm? Is there really much of an increase in power from the 70mm? Any input on the matter would be appreciated. Thanks!
  2. Gadget
    10,862
    122
    The 70mm is easier because it fits up to everything. The 76 requires a new boot.
    Torspd likes this.
  3. o0opackersfano0o
    Jun 23, 2016
    401
    85
    go big or go home. i have the 76mm. installed it when i put the supercharger on so cant really tell u how different it feels
  4. NHXRUNNER
    7,694
    200
    I'm running the 76mm. I ran into a leak at the TB and adapter interface initially. And I've also had an intermittent P0505 code. I got my TB second hand some I'm not sure if the TB is sticking or if I still haven't knocked out the leak 100%. But the butt Dyno says I got a small bump in hp. My AFRs and fuel trims seem to be on par, maybe still a bit rich at certain RPM ranges. I'd recommend the upgrade. Cheap power if you can get the TB at a reasonable price.
  5. Superloki24
    Superloki24 Member
    Oct 24, 2009
    212
    19
    Did you ever figure out what was wrong with this?
    I'm getting the same code after doing the 76mm TB upgrade. I put silicone between the TB and adapter plate and used a new gasket between the adapter and the supercharger, so I don't think it would be a leak. It idles high and has some strange idle fluctuations as well as hanging onto to the rpms when I shift.
  6. o0opackersfano0o
    Jun 23, 2016
    401
    85
    i did the same 76mm upgrade. never had a code. but took forever for idle and revs to be normal. probably like 1000 miles. shes mint now tho
  7. NHXRUNNER
    7,694
    200
    It took my truck at least 500 if not 1000 miles to stop throwing that code. It did eventually stay off but it seemed to take FOREVER.
  8. SoFloBlue
    SoFloBlue Member
    Apr 4, 2016
    57
    12
    I have the 76mm as well, never had any codes. The idle took a while as well.
  9. throwinsparksatu
    Nov 8, 2015
    50
    I run 70 mm took ten mins all was well I used hi temp silicon and the gasket, I took out a throttle spacer and put this in , seemed equal
  10. uno808
    uno808 Member
    Nov 16, 2013
    where can you get the 76 tb?
  11. SoFloBlue
    SoFloBlue Member
    Apr 4, 2016
    57
    12
    Got mine on eBay, came off a 4Runner I believe. There is a thread on here somewhere that’s lists what year you can get them off of.
  12. o0opackersfano0o
    Jun 23, 2016
    401
    85
    I have one. I just did a small port and polish on it. Nothing big. And already backed the adjustment screw 1 turn. Pm me if interested.
    rjbiii likes this.
