SignUp Now!That would depend on what other combination of mods you run with it.
If you run a nice intake, and unstuffed exhaust you should see in the 10 RWHP range. If you run it with the stock air filter box and a stuffed up exhaust, not as much as other parts in the system would likely be more flow restrictive.
What about a supercharged truck with all the supporting exhaust?
Yea, OK, like do you want me to be like the other companies and make stuff up and publish an "UP TO 48 HP" or give you an real honest answer??
The honest answer is I have not tested it with every possible combination so I really cannot answer that. Now if you understand the concept you should be able to see how when you eliminate restrictions to the flow path in and out of the engine the power potential goes up.
how many mm is the stock valve? and is Tundra's throttle body cable or electronic?
so g man will the tundra throttle valve just hook up with no wiring required? i.e. plug and play, without a aftermarket ecm of any kind?
