Anyone disabled TC/VSC and installed LSD on an '09
Discussion in 'Stock Performance/Mechanical' started by LateOnTheBrakes, Oct 5, 2009.
  1. LateOnTheBrakes
    Aug 2, 2009
    310
    Do you disable the electronics every time you get in the truck? Or does the limited slippage between the two wheels keep the VSC from kicking in?
  2. STONER-X
    STONER-X Active Member
    May 15, 2008
    3,372
    just run the wheel sensor to the front tires...... then it will only come on if u start to spin out.... and do one hell of a dont YAAAAAAAAAAAAAAAAAA haha jk
  3. LateOnTheBrakes
    Aug 2, 2009
    310
    Front wheels both have their own sensors. They just use the ABS (wheel speed) sensor.
  4. gen2crvtec
    gen2crvtec New Member
    Aug 25, 2008
    374
    you could try unplugging your wheel speed sensors that was something i was thinking about
  5. LateOnTheBrakes
    Aug 2, 2009
    310
    What part number did you use for the LSD, and where did you get it? I'm trying to price out the LSD and the bearings, I will not be doing a gear swap though.
  6. darthyota
    darthyota Active Member
    Jul 22, 2009
    3,159
    best thing to do is just pull the fuses thats what i did after i found out all those systems are there to be a nanny and not let me have any fun, only downside to this is you loose your abs too which in the summer when i run the truck like that isnt an issue for me. once i get some more cash i to will be putting in a tru trac. now that its winter however i have my traction control and abs fuses back in just to keep the truck stable and controllabe when its this slick out.
  7. Yotaxrunner10
    Yotaxrunner10 New Member
    Nov 30, 2014
    25
    Anyone got this figured out yet on our 09 + xrunners?? I just purchased a tt 913a541.....anyways will be getting it put in for my birthday.....I guess I'll let you guys know how it goes. Quick question is there any other parts I will need other than diff fluid?
    Thanks.
  8. Blue10XR
    Blue10XR Member
    Dec 13, 2014
    342
    20
    I have the trutrac kit sitting in my garage. It comes with everything you need except gear oil and tools to install it. I am looking for a pumpkin if anyone has one. That way I can keep my stock in the event I need to swap. I may change my ratio while I'm at it.
  9. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    848
    29
    Eaton recommends redline shockproof. You also need bearings and thread locker. I purchased a new gasket when I did mine. It is very thin most guys just use RTV
  10. RacerX
    RacerX OneNastyMan
    Jan 22, 2018
    6
    If you disconnect 1 wheel speed sensor, the VSC/ABS should disable cause it needs all or it becomes a logic fault.
  11. autobodyX
    Aug 8, 2010
    848
    29
    I prefer to introduce a engine ECU fault to disable the stability control. Doing so allows the ABS to function if it is needed. You have to replete the fault every 5th key cycle or introduce a more permanent fault.
