APR T56 Swap!!!!!!
turbomach1
Here is a 40-90
[ame]http://www.youtube.com/watch?v=Y66Q_KuisTA&feature=youtube_gdata_player[/ame]
turbomach1
Don't know if this is bc of the swap or not. Yesterday I was coasting down the road in neutral rolling about 60 or so. I decide to see what would happened if I tried to set cruise control. As soon as I let off the button the rpm jumped up like it thought it was in gear. Tapped the brake and it dropped.
Just wondering if a stock X does the same thing.
X-FREAK
That is weird... Never tried setting cruise in neutral but now I'm interested to try and see what happens
Murderface
If u have the cruise set and push the shifter into neutral without using the clutch the engine will rev up to redline as if u floored it
That's becauae your clutch switch is bypassed. Possibly for a renote alarm or such
turbomach1
7500 miles on it now. Pulled a 16 foot trailer with 71 Chevy c10 pickup with it since then too. Loving the set up. Gettin around 18 mpg. Kinda in the air about supercharging it or swapping a lsx motor in it. Tried asking one guy on here about how he hooked up a/c on his ls1 swap, but he/she never respond back. Sure I can figure out. Just wish he would help out.
The clutch grabs real good. Rainy days are loads of fun.:biggrin:
The switch is still hooked up. Have to push it to crank it
Rexrunner did the swap as well. Did you ask him, or the other member about the A/C?
9546849109 is my cell. Feel free to call or text. Anyone rather that...ibdont check my inbox much
You will need a pulse latch relay which allows the momentary action of the factory button to turn a circuit on and leave it in that position until it recieves another pulse to de activate. In turn turns a momentart switch to a constant switch
There is one wire you will need to hook up to that relay to get the ac light to light up as desired. Ill check mine
Im using a corvette flash so my pcm is pinned accordingly. My flash only requires a high pressure switch to turn on which gets soldered into the ac lines.
There is also another relay that needs to be tapped into under the hood to the pcm. The pcm knows when you request ac but it needs more from two wires telling it that 1 the relay got a 12v signal to latch and 2 to confirm that it latched and that the compressor in turn is getting a 12v signal to latch its mag clutch.
Hope this helps
turbomach1
Thanks. I will hit you up when I get all of it up and running again after the swap.
There is 2 clucth swicthes. One for starting and one for cruise control
X-FREAK
I tried this all factory no switches bypassed and pushed the clutch in to go into neutral and it still tried to rev up when setting cruise, Must just be how it is from the factory there is no safety override for it
revobreaker
How did that remote bleeder work out for you? Didnt see any more post about the install so I guess it went in easy and worked properly?
I hope it worked well. I am getting one as well. That AC Delco bleeder is just messy and a pain.
