Apr x1 launch control
Discussion in 'How-To' started by JPAYNE722, Nov 23, 2016.
  1. JPAYNE722
    JPAYNE722 Active Member
    Oct 26, 2011
    1,192
    i can't figure it out for the life of me,I can change the numbers but it won't save
    Also which do you prefer
    2800rpm 18 degrees out 1.45 timer orrrrrrr
    3000rpm 15 degrees out 1.500 timer
  2. Gadget
    10,875
    127
    Make the changes. Check the box near the cal name to save it. Then copy it out of the xtune directory onto your flash drive. Then prefix it with the correct prefix. I think it is X1. Then it should work.
  3. JPAYNE722
    Oct 26, 2011
    1,192
    So on the flash drive,I'm renaming the tita40 in aprcal to x1
  4. Gadget
    10,875
    127
    No, prefix with x1.
  5. Gadget
    10,875
    127
    On the flash drive
  6. JPAYNE722
    Oct 26, 2011
    1,192
    I'm confused I'm real sorry so for example,in the aprcal folder on the flash drive it's going to be x1Tta40.03A.F4.295?
  7. shane881510
    shane881510 Member
    Feb 14, 2010
    868
    24
    Idk about ur truck but mine won't launch with them times. Mine is set at about .5 to .75 of a sec on time at about 2800 at -11 degree for street tires and about the same for drag tire but with 3500 rpm launch
  8. Gadget
    10,875
    127
    X1.Tta40.03A.F4.295 If that is what you cal actually is. Does not look right. Sure it is not Tta40.03A.F4_295.some two digit numer
  9. JPAYNE722
    Oct 26, 2011
    1,192
    Okay I'll try that,thank you,What's the best degrees out do you think,and my file is Tta40.04XF.F3_295.01
  10. shane881510
    shane881510 Member
    Feb 14, 2010
    868
    24
    Degrees to be took out is something u would have to play around with same as rpm. I set and practice and try difference combination until I like it then I'll save it to the flash drive. I started at -10 then went up and down from there. My worst problem is the 1st to 2nd gear change its so far apart that 2nd rele drops the rpm down so far its hard to pick up without making a lot of speed from 1st.
  11. JPAYNE722
    Oct 26, 2011
    1,192
    Are you n/a? And the time thing is that how long it drags it out or how long you can be on 2step
  12. shane881510
    shane881510 Member
    Feb 14, 2010
    868
    24
    I'm supercharged, yea time is how long the two step is still active once u release the clutch.
  13. JPAYNE722
    Oct 26, 2011
    1,192
    I'll try in the middle maybe 1.5 or 1.00
  14. JPAYNE722
    Oct 26, 2011
    1,192
    I keep getting this :mad::mad:
  15. JPAYNE722
    Oct 26, 2011
    1,192
    Every time I change the numbers,and click the save button that appears
