ARP Head Stud / Cam Oil Control Valve Clearance Issue
Discussion in 'F/I Mods & Tuning' started by akakrill, Sep 10, 2016.
  1. akakrill
    akakrill Member
    Mar 26, 2007
    944
    I have my motor back, built short block with heads torqued on with ARP head studs supplied from Dezod. I began the reassembly of the cams, timing chain and covers, As I was finishing up my valve covers, I decided to install the Cam Oil Control Valves... Well the passenger side didn't go in fully as pictured... I got out the flash light and out came the expletives. It appears the top of the head stud is in the way.
    Has anyone experienced this? What is the issue? Do I have the wrong model? I am in contact with my builder and we are working a resolution.
    Just wanted to learn about why this might have happened. Ideas?
  2. Gadget
    10,830
    102
    Is the stud part extending to high above the nut?
  3. akakrill
    akakrill Member
    Mar 26, 2007
    944
    yes, that's exactly whats happening
  4. Gadget
    10,830
    102
    You will need to shorten it. If it was a kit for that engine it should of come ready to go.
    Count the threads you need to remove. Remove the stud and slowly grind it down very little at a time so it does not get hot and change the heat treating of the stud. Then reinstall and torque.
  5. Torspd
    40
    Yup. Seems that for some reason the studs from Dezod are a little longer than the studs from LC Engineering. Clearly they are different length part numbers. Which creates that one clearance issue with the OCV. I have both sets of studs, and encountered this with the set received with my Goldylocks engine.
  6. akakrill
    akakrill Member
    Mar 26, 2007
    944
    Another look for someone else's benefit :thumbdown:....
    Anyway problem resolved...
    Day 3 finish state...need some URD button heads to continue
    Ready for Tow and install..
  7. akakrill
    akakrill Member
    Mar 26, 2007
    944
    Can anyone confirm the 4WD oil pan fits the x runner without modification?
  8. NHXRUNNER
    7,515
    127
    Slywhitty did it I THINK...
  9. NHXRUNNER
    7,515
    127
  10. Slywhitty
    Slywhitty "Midget Magnet"
    Jan 26, 2008
    3,380
    6
    It does. It's real tight though. over 60k miles since it went in and not a problem even with all the auto cross and other racing I do
  11. Torspd
    40
    Hell yeah man!!!!
    I believe that some people had to grind just a hair of the cross member in one spot. So be prepared for that potential.
    Here are mine, to concur.
    Now time to boost it up like this guy's! :D
    https://youtu.be/DInFfStbw5g
  12. Slywhitty
    Jan 26, 2008
    3,380
    6
    I did that. As well as a little love from a BFH. Lol
    #12 Slywhitty, Sep 12, 2016
  13. XMPLRY808
    XMPLRY808 Active Member
    Dec 5, 2014
    341
    32
    I seen that video too torspd! Any info on it??
  14. Torspd
    40
    Only info I have is what he added into the description. 805 whp, Tranzilla T56, and rebuilt engine. Which means probably a sleeved engine. The previous iteration was~630 whp on the oem trans.
  15. Torspd
    40
    Which sized rotrex do you have Akakrill?
  16. NHXRUNNER
    7,515
    127
    Think he's running the 81
  17. Torspd
    40
  18. NHXRUNNER
    7,515
    127
    He drove it to XFEST. Ran great. His wife continued to drive it to put more miles on it (his commute to work is really short). Think it's seeing full boost these days. I hope to get some video with him this weekend. Tony (new guy from Maine) and I are going up to run the Kancamangus Highway with him on Sunday.
  19. Torspd
    40
    Hell yeah. Sounds good
