bang when stopping??
Discussion in 'Stock Performance/Mechanical' started by BSPX, Sep 21, 2007.
  1. BSPX
    BSPX Member
    May 14, 2007
    583
    Everytime I go to stop I will put it in neutral and cruise to a stop, but a second or two after I stop it feels like someone rearends my truck. Its a pretty strong jolt that is felt and heard in the drivetrain. Its starting to do it more consistently now. My dealer wont ever look at it, I have been there 16 times now. I am thinking the only thing it could be are the synchos?? Anyone have any ideas?
  2. Xample
    Xample New Member
    Jun 3, 2007
    2,478
    may be your u joints are bad?? jack up your truck and check the play in them:dontknow: thats all i can think of
  3. BSPX
    BSPX Member
    May 14, 2007
    583
    i thought of that, I tried to move them and there isnt much play, but I do have a vibration now at 80-85 mph when I let off the gas and a random metallic ring sometimes.
  4. Xample
    Xample New Member
    Jun 3, 2007
    2,478
    sounds like it may be in the rear then...is the diff chattering on aggressive drivin?
  5. Xample
    Xample New Member
    Jun 3, 2007
    2,478
    how many miles do you have on this??
  6. nctourer
    nctourer New Member
    Any reason given as to why they wont look at it??
  7. project-c2
    project-c2 New Member
    Feb 27, 2007
    1,880
    Should try test drive with the tech. When stuff like this happens @ my work place. I suggest test driving with the customer. Better than saying "unable to verify complaint.":dontknow:
  8. My68ur8trd
    My68ur8trd Active Member
    4,672
    sounds like axle wrap. on my 99 it would wrap up to where the slip yoke would get stuck. when it releases it feels like you get hit in the back. I wouldnt think that would happen on these trucks. I was on 35s with 9" lift when I had that problem
    Justin
  9. wshsbears
    wshsbears New Member
    2,514
    if ur in neutral.. how does ur drivetrain do anything but make noise? if it feels like ur getting rear ended, that would mean ur drivetrain is engaging for a split second. there is a TSB out for the throwout bearing. the bearing could be defective and catching on its own internals causing the drive shaft to jerk ur truck around a little.
    i get the high pitch whine at speed too. its the certain point where ur engine and drivetrain aren't helping each other out and if u think about a semi who keeps getting on and off the gas, it makes the same noise, just much louder.
  10. BSPX
    BSPX Member
    May 14, 2007
    583
    the LSD clanks pretty bad when I turn in neutral only. Last night i got it to bang like that when I was slowly backing up into a parking spot. I dont think its the throwout bearing, it doesnt make any noise when I engage the clutch. The truck has 5100 miles on it. It also doesnt make a chattering noise on acceleration either.
  11. wshsbears
    2,514
    what im sayin is, the drivetrain would have to be engaged in someway for anything in the back end to move. esp to make a loud noise. when ur stopped ur gears in ur back end are stopped too. if ur clutch engage for a split second, it will move ur back end.
  12. BSPX
    BSPX Member
    May 14, 2007
    583
    so then it could be the synchros in the tranny?
  13. Lynxshd
    Lynxshd Member
    Feb 8, 2013
    40
    Did you ever get this resolved. My truck does the same thing and has since new.
    thewarriordinghy likes this.
  14. AryaHmmr
    AryaHmmr New Member
    Dec 27, 2011
    12
    Mine has been doing this lately, it's not a strong jolt though, but definitely feels like a light bump a few seconds after I come to a complete stop. Did you get this issue resolved?
  15. blu xr
    blu xr Member
    Jan 13, 2011
    898
    13
    back when i had a 2000 ws6 it did a similar thing. when i would go to stop, i would get a clunk sound when slowing down or hitting the brakes...felt a "bump" too. over time it would get worse.
    finally discovered that it was loose u-bolts on rear axels. when the previous owner lowered the car he must not have tightened up the bolts enough or they just loosened up over time because of the high hp. when applying the brakes it would "shift" and probably even compress the driveshaft too.
    ended up putting lock washers on it and that solved the problem. not sure if it is the same problem, but its worth checking out. good luck guys...
  16. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,974
    72
    I used to get a thump when hitting my brakes, but it was in the front. After much frustration, I finally figured it out.... my battery tie-down was loose and the battery would shift under braking. Swapped to a nylock nut and problem solved!
    Not the same problem as you're having, but it just reminded me of mine...
    Good luck!
