Blacking out the tail lights?
Discussion in 'Exterior Modifications' started by Rat Rod, Jun 8, 2009.
  1. Rat Rod
    Rat Rod "Blade"
    May 4, 2009
    4,660
    how much and how long did it cost and take for you to get black tails on your truck and if anyone knows a good spot to do them in houston
  2. blazinx
    blazinx Active Member
    Mar 3, 2007
    1,989
    i can do them we can meet up and talk bout price
  3. xrunner224
    xrunner224 New Member
    Apr 8, 2009
    566
    you can do it yourself
    with about
    30min or less
    and window tint spray
  4. blazinx
    Mar 3, 2007
    1,989
    i wouldnt use that stuff its a wast of money but thats my 2 cents i use automotive clear and black
  5. RJDoute
    RJDoute "My Salami Nipples Ooze Milk"
    Mar 4, 2008
    3,360
    Automotive clear and black/tint is the only way to go.. pretty easy job if you have the tools. :top: 80/20 mixture or so.
  6. dmbfan73
    dmbfan73 Active Member
    Sep 23, 2008
    1,156
    i've used the spray tint from hobby shops and vht nite shades, vht works much better IMO.
  7. braves011
    braves011 "Crouching Tiger"
    Mar 25, 2008
    4,973
    :dito: autopaint and clear is the only way to do it one reason i like that is i useally wax them when i wax the truck. also the window tint will come off in time. theres someone in Houston who does them i wanting to say its Grumpy but can't remember exactly. heres a pic of mine wshsbears did mine and i'm wanting to say its 90/10 its noot too dark.
  8. Rat Rod
    Rat Rod "Blade"
    May 4, 2009
    4,660
    hmm thanks for the input ill be thinkin bout it for awhile i need a job first
  9. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    Grumpy has done several sets.
    I used VHT on mine, but I shot over it with clear. I do think using automotive quality paints results in a better job.
    before
    after
  10. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    More pictures coupe!
  11. Rat Rod
    Rat Rod "Blade"
    May 4, 2009
    4,660
    i like the look braves has goin on nice and dark buut still visible as for who i could ask to do it blazin or coupe hmm what incentives do yall offer?:biggrin:
  12. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    These are a little dated. I need to take a few new ones.
    [​IMG][​IMG]
    Grumpy's will look better. Mine was done with a rattle can. They look good, but Grumpy's or Blazin X is going to look much better.
    #12 Coupe, Jun 8, 2009
  13. blazinx
    Mar 3, 2007
    1,989
    im not sure if grumy can still do it but i can for sure i work at a body shop so i could swap u all three of mine and then get urs done and swap back with a small cash donation to me :top:
  14. Viet2100
    Viet2100 New Member
    Dec 22, 2007
    488
    Automotive black + clear FTW!
  15. Coopstain
    Coopstain Active Member
    Dec 14, 2007
    1,094
    wshsbears did mine too.... 90% Clear 10% Automotive Black applied with a spray gun. These are only one good coat. I think they are PERFECT and i have heard wshsbears tell people these were the best shade that he has ever done (he gets a lil crazy with the spray gun and likes to go real dark lol). Anyways... these are just right... they are dark, but you can still see a lil red tint from the lense.. have had no problem with cops either!
  16. llicrxjr84
    llicrxjr84 New Member
    Jun 3, 2009
    another way to do it is to get the smoked lens...can cost a lil money...but it wont damage ur lens like painting would...
  17. X_Less
    X_Less Member
    May 25, 2009
    825
    Alexxxwing and Gen2Crvtec got together and did gen2crvtecs tail lights... From what i recall.
    Get tint spray (nightshade i believe was the name?)Use a scuff pad to scuff the tail lights until its all hazey, Use even coats and every other coat let dry for like 3-5 minutes until you get the desired amount of tint... Do not forget to clear after the tint has dried... I think they did like 4-5 coats of clear.
    When done with this process it will not look "perfect" it will be bumpy, depending on your skills you might have some run marks... Do not fret... Depending on how much sun exposure your truck gets 48 hours-a week til fully cured... Me and gen2crvtec waited 4 days (i think) to wetsand them.
    Get some 2000 grit sand paper and begin wet sanding evenly and TAKE YOUR TIME. This process takes awhile depending on the type of clear and how it was sprayed on... wet sand until the surface is super smooth and when wet looks perfect. Once you dry it off it will look like shit.
    I used 3M Rubbing compound and PlastX on the tail lights with a 10" orbital buffer and polishing bonnet... Afew coats on the tail lights with these compounds it looks great... but be known when you get wax inside the edges on the tail lights... It's a pain in the ass to get out... I found a thin rag and a knife works...
  18. music_man185
    music_man185 New Member
    May 17, 2009
    132
    that looks real good! what kind/brand did you use and how many coats? i have a brand new can of vht night shades waiting on me. i just didn't know what kind of clearcoat to use. i was afraid any rattle can clearcoat would give me a dull look instead of glossy. but yours looks pretty damn good.
  19. rich017
    rich017 Active Member
    Aug 23, 2007
    6,328
    Mix a 9 to 1 ratio of Automotive black lacquer/automotive clear lacquer.
    So basically the mixture is 90% clear and mixed into a spray gun. The more coats, the darker it gets without really affecting light output
  20. Viet2100
    Viet2100 New Member
    Dec 22, 2007
    488
    It's not rattle can, it was done at my buddy's house with his paint gun.
