Bleed your clutch!
Discussion in 'Fluids & Maintenance' started by Justin Kantor, Mar 12, 2018.
  1. Justin Kantor
    Justin Kantor Member
    Dec 18, 2017
    32
    I never though such a little thing would improve performance but bleeding the clutch helps the transmission engagement greatly. I had a little bit of grinding on 3rd and 5th and thought it was the synchros going on those. I swapped for a higher performing transmission oil which helped but did not get rid of it. I bled the clutch and a nasty, black, fluid came out and performance is better than I have ever had. I even put a Speed Bleeder on which made it a 1 person job. I am glad I don't need to investigate a synchro service as I have heard nightmares in success or failure.
  2. spicciani2
    spicciani2 Member
    Feb 22, 2018
    56
    10
    What size does it require? nothing listed for 2005+
    95-04 Tacoma (2WD Exc. PreRunner) 639570 - - -
    98-04 Tacoma 2WD PreRunner 639560 - - -
    95-04 Tacoma (4WD) 639560
  3. Justin Kantor
    Dec 18, 2017
    32
  4. spicciani2
    spicciani2 Member
    Feb 22, 2018
    56
    10
    Just for the rear?
  5. Justin Kantor
    Dec 18, 2017
    32
    I only used the bleed at the rear of the transmission as I believe it bleeds the whole system. The reservoir is quite small that is attached to the brake fluid reservoir so make sure it does not go empty. I only replaced the rear bleeder because it's easy to get to.
  6. spicciani2
    spicciani2 Member
    Feb 22, 2018
    56
    10
    Ah right my bad I was thinking of the brake system too....
  7. Justin Kantor
    Dec 18, 2017
    32
    Did that as well on the fronts and rear. I do a lot of my own work as it is way cheaper.
