Blown Motor, coming back stronger
Discussion in 'F/I Mods & Tuning' started by Torspd, Jun 12, 2009.
  1. Torspd
    51
    Success!!! The motor install went very well. So here are some pics.
    The ARP head studs. All torqued down.
    About to set up timing.
    Hmmm????? o_O
    Here is the knowledge I wanted to share about the oil pans. I.E.:
    win pan - left. dmb - right
    Here are the close up differences. Look at how much deeper the drain pan is on the 4x4/PreRunner oil pan.
    As you can tell the 4x4 model is much deeper. Better for high G cornering and hill climbing. The 2wd/Xrunner pan is much thinner. If you don't have at full on the dipstick and do to much extended turning, you can easily deprive some rod bearings of desperately needed oil. So be careful (full) or swap (if possible).
    Here is the start up vid by Grumpy. Not much to see...just a motor...
    http://www.youtube.com/watch?v=sINNPNnBG-I
    #481 Torspd, Apr 16, 2010
  2. Gadget
    10,899
    148
    Torspd 3.0
    love it!!
  3. Super Werty
    Super Werty Active Member
    Jul 12, 2007
    6,283
    sweetness! Can't wait to go for a ride:rock:
  4. ntinhri
    ntinhri Active Member
    Feb 1, 2007
    8,104
    Sounds like a valve or a exhaust leak.. I bet you were very happy it started!!!
  5. Torspd
    51
    That noise had me for a second also. The backets that support the headers that are attached to the transmission were both loose. The bolts going into the bottom of the headers were also. Easy fix.
    This is also the first time I've had the chance to run a few new things on my truck. One, is a pair of copper gaskets that I had made to go between the header to Y-pipe. The other is a ninja hiding somewhere around the intake. o_O. I'll post a pic tonight.
  6. 5H4D0WD347H
    5H4D0WD347H New Member
    Apr 24, 2007
    10,450
    w00t x3
    What kind of assembly lube is that man? Looks like hand lotion, getting a little happy too early mark?
    Your tires are flat!
    Get some vids tearing it up after the break in dude.
    #486 5H4D0WD347H, Apr 16, 2010
  7. SpaceMonkey
    SpaceMonkey New Member
    Jan 4, 2008
    1,610
    It's alive! Congrats!
  8. 5000XD
    5000XD New Member
    3,774
    Pretty sweet! I wanna see this thing drive :top:
  9. SX TOY
    SX TOY Active Member
    May 23, 2009
    1,965
    right on bro love to see a full build list.
    I am acquiring a block soon so that I can make the slow road to boost myself.
    that killerglass rad hose looks badass :top:
    bring on the BOOOOOOOOOST
  10. blackx07
    blackx07 Active Member
    Nov 24, 2007
    1,752
    i followed this whole thread and now ill finally post.
    im glad to see its all back together and up and running again.
    last time i rode in this thing i almost cried from pure joy
    good work bro :top:
  11. dwntwnall4u
    dwntwnall4u Member
    Dec 9, 2008
    113
    Yes, you're back up running. Waiting to hear more on the build and future front suspension.:top:
  12. T0LLPHR33
    T0LLPHR33 "Catwoman"
    Jun 17, 2008
    10,969
    congrats mark...glad to see and hear the truck is back up and running...:top: TORPSD 3.0 FTMFW!!!...:rockon:
    you definitely got the longest build thread...:biggrin:
  13. Torspd
    51
    TORSPD 3.0 Hell mf yeah! I drove it to work today. Every thing seems fine. Might have a small vacuum leak. Have to check tonight. Feels real good so we will see.
    Shouldn't be to long before I can get into the boost. I want to do some data logs so I can make sure all is going well.
    New coilover will be back on track by Saturday.
    That killer glass has been a bit of a savior before, and I finally got the chance to put the lower one in as well.
    Thanks guys for all of the support on what has to be the longest build thread ever.....lol
    Lunch time, so I will repost all specs later
  14. rexrunner
    rexrunner Active Member
    did that sts put any impressive numbers down when it was running? :crinklehair:
  15. NHXRUNNER
    7,899
    267
    Congrats Mark. Job well done my friend. Wish you the best for the long haul this time :top:
  16. Torspd
    51
    Thank you. Long term long haul for sure.
    It did alright on these 35's. The #'s are in my sig.
    No vacuum leaks or exhaust leaks also.
  17. Torspd
    51
    Well I had though I had a possible vacuum leak earlier. So I did a little testing and some swapping of parts. The truck was kinda chugging like it was having a hard time accelerating. I ethought maybe it was having a hard time breathing also.
    So I swapped out to a newer air filter. Moved around some vacuum hoses and checked over all the ailicone couplings.
    Went for another test drive...
    I opened the back window so I could listen to the turbo. I could hear it, but it had been so long I couldn't remember exactly how it was supposed to sound.
    I gave it gas. Watched the boost gauge. Wouldn't get into boost. Not even 1 psi. WTF??? Tried it again. Same. Tried it again. Same. Then all of a sudden I could really hear the turbo. BOOST!
    I think some how the turbo was gummed up or something. Now my truck is running great. Only got into 3 psi for now.
    On another note, I did a slight tapper/port to my DTLT's. They come with a 36mm opening. Stock header have a 42 mm opening that tapers down to 36mm. So I ported the opening to 40mm. The point is, that it flows better now, and the rasp at 3k rpms has subsided so much now, I really like the sound. Odd that.
  18. Tapp
    Tapp New Member
    May 2, 2007
    4,383
    got any pics of the headers now... how far back did you taper them?
  19. SpaceMonkey
    Jan 4, 2008
    1,610
    Good work on the ported headers Mark. And glad to hear your truck is running fine.
  20. Torspd
    51
    Tapp - Sorry but I don't have any pics on the headers. I just got the idea from the other member that posted the thread "Ported Headers" and went with it. Side by side with the Stockers, it is an eye opener. Plus if you take them off, you will notice a much thicker black exhaust ring than the stockers. Apparent sign of restriction.
