BMWtech's Turbo Build
Discussion in 'Member Builds' started by BMWtech, Dec 6, 2015.
  1. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I figured its about time that I start a thread for my truck after lurking in the shadows on the forum for the past many years. I purchased the Turbo kit that Stoner X was selling and have been collecting parts for the install over the past couple months. I'm usually really busy between work and my motorcycle racing addiction but I'll try to post regularly with the progress of the build. For now is what the truck currently looks like....
  2. 8o8drifter
    8o8drifter Member
    Sep 11, 2009
    229
    Right on i get to see a beast emerge outta the darkness
  3. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,339
    21
    Should post up wheat you have done to the truck already. I can see the bhlm and a bbk on there already.
  4. Torspd
    47
    Cheating with a lift. :eviltongue: This will be good. :top: Keep them coming.
  5. Doublld
    Doublld Active Member
    Jun 12, 2013
    1,089
    20
    perks of working at shops lol :top:
  6. triumphx
    triumphx New Member
    Mar 30, 2011
    1,920
    Bump for my old turbo kit!
  7. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    Yeah I've been spoiled by working on a lift for so many years. I avoid doing anything on the ground if at all possible. I spend too much time hunched over in the garage working on the bikes that I would rather not do it on the truck.
    Current mods on the truck
    URD Maf Caf, DTLT, Intake Manifold Spacer, Gen 1 TRD intake, 3in Cat back, StopTech BBK, URD SS, BHLM, Stubby antenna, a bunch of stereo stuff.
    Mods to be installed before or around the same time as the Turbo kit (most of which I already have or is in the mail on the way)
    URD stage 3 clutch & upgraded throwout bearing
    UCON, w/tstat, cam gears, etc
    61lb injectors
    URD fuel pump kit with Walboro 255
    70mm throttle body w/URD adaptor (still trying to find a decent deal on the damn TB)
    Innovative Wide band
    Boost/vacuum gauge
    New Denso sprark plugs
    Vibrant 3in bottle style resonator after the downpipe, to a QTP electronic Cutout, and also adding a Vibrant ultra Quiet resonator behind the cutout.
    GReddy Oil filter block adaptor
    Manual boost controller
    and a probably a few other things that I'm forgetting. I'll be installing most of the items one by one to prep for the turbo kit install over the next few weeks. Hopefully this week I can find time to install the fuel pump kit and maybe the UCON. I'll try to keep you guys updated with the progress.
  8. rennurx
    rennurx New Member
    Sep 22, 2011
    1,736
    Figure out a plan for a new intake manifold and don't let anyone tell you otherwise..
  9. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I'm assuming that the stock manifold can't handle the pressure?
  10. STONER-X
    STONER-X Active Member
    May 15, 2008
    3,372
    It a mix of your turbo and rennurx's kit
    But none the less still these kits have been on only black x runners :biggrin:
  11. NHXRUNNER
    7,718
    209
    There's a flap valve that changes the length of the intake runner within the stock intake manifold. There are screws that hold that flap to the rod on which it rotates. A few people have sent those screws through the engine under boost. It's a rare occurrence and nobody have been able to prove that the valve is seeing additional strain under boost. That being said, it's happened a couple times that I know of and rennurx is one of the unlucky ones. :top:
  12. STONER-X
    May 15, 2008
    3,372
    2 truck that I know of... rennurx and sdx..
    I ran the 7 psi 30-40000 miles turbid and 90000 boosted total zero issues
  13. x-runner kid
    Oct 11, 2007
    1,339
    21
    Can you just take the valve out?
  14. Doublld
    Jun 12, 2013
    1,089
    20
    i dont think so. its plastic welded in there? i may be wrong. i just zip tied mine an disconnected the vac hose
  15. rennurx
    rennurx New Member
    Sep 22, 2011
    1,736
    If you want i think my buddy still has all the parts for the intake I was gonna make, I can finish it for ya. It would be a one and only so any testing you would have to do, But it uses velocity stacks and short runners, so more low end tq and let the turbo handle the top end!
    I wanted to finish it but never had a buyer and didn't wanna spend more money in it for no reason. So if u have any interest let me know.
  16. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I may be interested just really depends on cost at this point. With the holidays coming up, money already spent on truck mods, and rebuilding two R6 engines for next race season I feel like I've been hemorrhaging $$$$
  17. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    Stayed late at work this evening and installed the URD fuel pump kit. Took me about two hours. Should've been done with it faster but too many people where bullshitting around wondering what I was doing haha.
  18. Torspd
    47
    I know the hemorrhaging money feeling.....still making progess though. Keep those updates coming.
    How long until you can start the engine bay aspect?
  19. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    Its probably going to be a little while. I wanted to get the clutch in there first but I'm still waiting on it to come in the mail. Was debating on going in to work today and installing the thermostat and cam gears but I'm currently lacking motivation. Can anyone chime in on running the cam gears without having the UCON installed. I don't really see it as being an issue but maybe I'm wrong.
  20. Torspd
    47
    Don't add the cam gears since you'll be turbo. If I remember correctly, it will change the overlap between intake and exhaust. Which will allow boost air back into the intake.
