BMWtech's Turbo Build
Discussion in 'Member Builds' started by BMWtech, Dec 6, 2015.
  1. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,339
    21
    Once that clutch breaks in after about 1k miles it's way different than stock. At least that's how my stage 3+ URD clutch is with a lightweight steel flywheel. Started out being much easier than stock and slowly broke it in and the more I drove it the more aggressive it became (I was very glad).
  2. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I've been really busy the past couple months with motorcycle race season starting back in Feb. Still still have one more engine to rebuild so modding the truck has been a little low on my list of things to get done.
    I pretty much have everything I need now for install minus getting with Gadget for a calibration file for the UCON. Hopefully here in the next month or two I'll do the install over a weekend.
    I have done a couple mods recently though. Installed a new steering wheel :rockon:
    I also decided to go a different route with my rear suspension. I know most guys use the QA1's for rear shocks but I've always been a fan of Koni and have used them on quite a few BMW's in the past. One of my good friends sells BMW parts for a living and does suspension builds for his customers. Its fairly common practice that the Koni 1186sport shock is used on BMW e36 and e46 suspension builds but if you run the part number it is spec'd for mid 2000's Ford mustang GTs. My friend had some extra ones laying around and we compared all the measurements to the stock X-runner shock. If i remember correctly overall length was maybe one inch different and the only issue was that the sleeve in the rubber bushing on the Koni was too long to fit the X-runner but the width of the bushing was dead on. So I decided to try it. I had to grind the sleeve flush with the bushing and they fit perfectly. Only other problem is that the supplied Koni adjustment knob won't fit on top of the shock on the drivers side due to clearance with the bed of the truck. I improvised and made my own adjustment tool out of some aluminum plate that I had laying around at work. What I made is very similar to this but was free and took about 15min to make.
    http://www.good-win-racing.com/Mazda-Performance-Part/61-1272.html
    They've only been on the truck for two days. I had them set to full soft yesterday and they seemed quite a bit softer than stock with a very comfortable ride. Today I set them 180 degrees from full soft and they feel much firmer but still have a good ride. Pretty happy with them so far!
  3. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    14
    I have a set on my wife's mustang. They are pretty nice.
  4. shane881510
    shane881510 Member
    Feb 14, 2010
    868
    24
    I want that steering wheel.where and how let's hear it.
  5. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I found it randomly searching on eBay at the beginning of march. A guy in Connecticut had it on his truck and removed it when he traded the truck in. I inquired about it and supposedly it is an OE Toyota Hilux steering wheel that had been modified and rewrapped. I didn't ask where he got it from but its looks almost identical to this one on eBay.
    http://www.ebay.com/itm/TOYOTA-TACO...ash=item43eb1a54ec:g:gNwAAOSwEeFU~lYH&vxp=mtr
    I'm unsure if thats the one I have but it appears to be damn close. It accepts the factory airbag and steering wheel controls/trim perfectly. The splines match the steering column as well. The only issue i ran into (which the seller neglected to mention) was that the way the steering wheel matches up to the slip ring was different. I ended up rotating the slip ring slightly to the right and it all went on and I've had zero issues. Its quite a bit thicker than stock and looks/feels pretty damn good! I may do some research and see if I can find a different slip right that will match up with it perfectly. I had never seen like it before and figured it would be a good addition to my build. Here is a close up pic of the leather and you can also see the red stitching.
  6. STONER-X
    STONER-X Active Member
    May 15, 2008
    3,372
    I like that wheel!! It is slick.. So much win..
    I cant wait to see that truck boosting!!
  7. Torspd
    47
    I like that leather and style. Curious how long the leather will last? As in what is your impression of the quality?
  8. MiamiChillin
    MiamiChillin Member
    May 30, 2015
    212
    Man that steering wheel is pretty dope. That one on ebay looks pretty much exactly the same too.
  9. *IrunnIt*
    *IrunnIt* Active Member
    Jan 7, 2010
    2,195
    15
    I've got one of those ebay steering wheels, its not on the truck yet I'm pretty sure this one is the same
  10. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    The quality seems pretty damn good. The leather is not near as nice as some of the stuff I see at work but those are also pricy BMW's.
  11. Torspd
    47
    Any further updates?
  12. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    I have a massive pile of parts ready to install that is occupying a large portion of my dining room. Pretty sure the wife isn't too happy about it. I should hopefully have my last R6 engine rebuilt this week. Only thing left after that is finish my engine build on the dirt bike and then I can focus on the truck. Hopefully will be installing everything later this month or early May. Still need a calibration file for the UCON but Gadget and I have been in contact this week so that should be taken care of soon.
  13. Torspd
    47
    Awesome :top:
  14. DGXR
    DGXR Member
    Aug 3, 2007
    687
    Looking good! :top:
  15. MiamiChillin
    MiamiChillin Member
    May 30, 2015
    212
    We have given you month. Where the updates at? haha:laugh:
  16. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    Sorry been super busy especially with all the flood cars we got in at work. Plus in the evenings I was rebuilding one of my R6 engines before the 3rd CMRA race round. A few shots of what I've been up to....
    I'm sure you guys will be especially interested in the last two pics. After work yesterday I mounted the intercooler. I'll be trimming the core support for piping clearance sometime today and then test fitting the rest of the cold side piping. I'm planning on full install this coming weekend. Things kind of worked out perfectly because my wife is headed out of town for work for the next two weeks. Between my supermoto and her X3 I'll have alternate transportation if needed. Also plenty of time to get stuff done. The plan is to take all parts to work on thursday and then on friday I'll take my Supermoto in the bed of the truck. Start install after work friday night. I'll leave the truck on the lift and use the bike to get home and then back on saturday morning. Hopefully finish on saturday. I'll have to baby the truck home and try to keep it out of boost because I'm not going to have proper calibration in the UCON. I'll have a session set up with Scott from Itronix on sunday to get the correct calibration files. To say the least I'm pretty excited! :blurock:
  17. MiamiChillin
    MiamiChillin Member
    May 30, 2015
    212
    Thats awesome man. Keep up the good work. I wish I new as much as you guys to strip shit down like that and customize how you please. I have some intermediate skills, but definitely not like that. Hopefully I will learn more when I start my drift missile project.
  18. Torspd
    47
    Woooo! Lots of excitement going on now. :top: Can't wait to hear you say that it is running like a champ!
  19. BMWtech
    BMWtech Member
    Mar 21, 2010
    145
    Well after a long day at work I was finally able to get the truck into the shop and start on it at about 6pm. I worked on it for about 2.5hrs before I had to head home to let my dogs out. I made some good progress. Exhaust is all out except for the long tubes, majority of the cold side piping is in, did an oil change and installed the greddy oil sandwich adaptor, spark plugs replaced and a few other small things. Headed back to work early in the morning on my supermoto to finish the install. Here is a teaser pic....
  20. Redlantern
    Redlantern Member
    Jan 28, 2013
    520
    Looking good man. Soon enough it'll be ready.
