Boost supporting mods?
triumphx
What u really need... well what are your specs? Size turbo and so on.
I would get a fuel pressure regulator. Ppl who dont and go forced induction dont make sense. Our factory one isnt boost reference. soo atock 43 psi fuel pressure with u running 7 psi is only 36 psi and so on. Get me? That's why everyone runs huuuuuge injectors to compensate. Get a regulator and you will be ok.
Get a cooler t stat ftom apr. Will help
What boost controller? Awesome man u will love it
Turbo i already listed its a precision knock off gt35, i have a fuel regulator even though this kit has ran fine without it. I have a apexi avcr boost controller.
If your running jba shorties you need that bung before the cat! If running catless anywhere in the y is fine, obviously further upstream the better, I have seen many members place their bung between the o2 sensors..
Sorry i didnt clarify, im going catless. ill prob place it on the y-pipe right after the header
Any where in either side of the Y or even the cat back portion. It is actually best to place it rear of the turbo because the pressurized pre-turbo exhaust will distort the readings of the AFR gauge. If not damage it. The only AFR gauge I know the likely has enough wire to do that is the AEM Uego wideband. Should be fine at 7 psi though. Get to 10 is where you start seeing funky things happening.
Also, was this an STS kit or made off of that design?
triumphx
Ok i got ya, i have a plx wideband from when my sentra was boosted and it has about 15 ft to play with. Ya im staying at 7 lbs so no worries there. Its not a sts kit, its custom. The guy i got it from said precision turbo used his truck to make a prototype which never ended up getting produced. It has jba ss headers, 3" custom ceramic coated y-pipe, burns mufflers(all exhaust is v-band), tial bov and wastegate, titan oil pump, precision intercooler, apexi boost controller, emanage, rc 550 injectors, walbro fuel pump, urd plug play harness, urd rear 02 sim and a aluminum intake box stamped precision.
Dayum! Now that is pretty bada$$! One of a kind there.
That one should give the APR one a little friendly competition. Will blow the STS kit out of the water.
Sounds like a legit setup. Do you have any pictures?.t
triumphx
Thanks im pretty excited about it, the guy put down 383 hp/400 lb at 7 psi on 91 octane. Ill get a few more with a tune for 93 octane. If you ever come to austin for anything holler at me as i could use a hand if possible man. I just picked up my xr a few months ago
Murderface
Just make sure the Wideband sensor is either in the 2 or 10 o'clock position. This will allow any moisture to drip out.
triumphx
Ya i had the wideband on my sentra when it was boosted, thanks for the tip though man
I have family in Austin, as well as friends. So that would be easy deal.
triumphx
That'd be awesome, i should have the rest of the small parts within a month or so. Just let me know when its good for you, Ill buy the beer and grub
Open a Photobucket account. Upload them. post img links here.
Good deal. I am quite curious to see this particular setup.
triumphx
I have one more question, what spark plugs should i run with this kit?
I am running Denso IKH27's. You will be fine with some IKH24's
triumphx
Heres some pics on photobucket, I got some denso spark plugs as well, thanks torspd. Sorry bout the weding pics they snuck in there some how as well with the bad pics. I had a giant ass coffee this morning ha. Let me know what you guys think... http://s921.photobucket.com/home/silverspecvser
Here you go :top:
Geez those fuzzy pics hurt my eyes. lol
triumphx
Thanks man, Ya that starbucks was like jet fuel thin am. Any clue where i can get a diagram of the ecu pinout? I've done some searching and came up with nothing. I have a urd p&p harness and want to tap into it so when my misc parts get here in a week or so ill be ready to rock!
