BUTT load of codes
Discussion in 'Stock Performance/Mechanical' started by JiNsEiGaNaI, Aug 26, 2015.
  1. JiNsEiGaNaI
    JiNsEiGaNaI Active Member
    Feb 20, 2011
    1,424
    I need help guys. My truck won't start. I don't know what caused it but seemed to come out of no where. I drive my truck only on the weekends. Tried to start it one weekend and it wouldn't turn over. I borrowed a scanner from a friend and this is what I got.
    Current
    B2799 - Driver water valve circuit short
    Readiness
    P0300 - Random misfire detected
    P0171 - System too lean (bank 1)
    P0172 - System too rich (bank 1)
    P0174 - System too lean (bank 2)
    P0175 - System too lean (bank 2)
    P0037 - HO2S heater control circuit low(Bank 1, sensor 2)
    P0038 - HO2S heater control circuit high(Bank 1, sensor 2)
    P0057 - HO2S heater control circuit low(Bank 2, sensor 2)
    P0058 - HO2S heater control circuit high(Bank 2, sensor 2)
    P0100 - Mass or Volume air flow circuit
    P0101 - Mass or Volume air flow circuit range/performance
    P0102 - Mass or Volume air flow circuit low input
    P0103 - Mass or Volume air flow circuit high input
    P011B -
    P0120 - throttle/pedal position sensor A circuit
    P0121 - throttle/pedal position sensor A circuit range/performance
    P0122 - throttle/pedal position sensor A circuit low input
    P0125 - Insufficient coolant temp for Closed loop fuel control
    P0128 - Coolant therostat (coolant temp below thermostat regulating temperature.
  2. hiflyer
    hiflyer Active Member
    1,892
    Check for chewed wires? Blown fuses?
  3. Doublld
    Doublld Active Member
    Jun 12, 2013
    1,089
    20
    it wouldnt turn over? does the engine crank or do nothing when you turn the key?
  4. JiNsEiGaNaI
    Feb 20, 2011
    1,424
    Engine cranks, got brand new battery and alternator, its just that last last part of firing up
  5. Gadget
    10,900
    149
    What if any mods do you have installed?
  6. Doublld
    Jun 12, 2013
    1,089
    20
    see if the car has fuel and spark? just look around for anything abnormal
  7. Torspd
    51
    Driver water valve circuit short???
  8. autobodyX
    autobodyX Active Member
    Aug 8, 2010
    860
    32
    People mess up electronics all the time unhooking the battery improperly. You have to disconnect the negative first and reinstall it last. I am saying put the positive on and tighten it up and then do the negative. If the positive moves and looses the connection momentary as you tighten it with the negative on one can confuse the electronics. And you probably pissed of the immobilizer.
    Not sure about drivers water valve I think your friend is messing with you.:laugh:
  9. JiNsEiGaNaI
    Feb 20, 2011
    1,424
    I have Trd intake(gen1), supercharger, alarm, flm, accessory lighting, thats all the mods i have in the engine bay.
    That i can think of, because my exhaust is stock(just changed muffler), stock pulley, just toyota reflash, i drove it the week before and nothing was wrong, so id why it didnt start! Last thing installed was the alternator and battery
  10. Doublld
    Jun 12, 2013
    1,089
    20
    doesnt matter either way trust me.
  11. Doublld
    Jun 12, 2013
    1,089
    20
    check efi fuses see if they are blown
  12. JiNsEiGaNaI
    Feb 20, 2011
    1,424
