fishsticks
Because fast lifted truck.
- Nov 29, 2015
- 207
- 8
What's the verdict on this? Mods in profile. Motor is higher mileage but still gives good compression on all 6. I'm using a 75mm pulley now and the stage 2/80lb injector calibration.
After the last round of mods, VE improved and it feels like my power band has shifted upwards a bit. I'm looking for more area "under the curve" in the 3-4K range. I have U-tune, but I'm resistant to adding timing since I travel a LOT and fuel quality can vary sometimes. I figure just squeezing a little more air in there will get me what I want.
I have plenty of fueling and the MK3 intercooler does a fine job of keeping IATs down. The truck errs on the rich side under power already (black tailpipe, 11-10 AFR on the gauge under heavy load). I'd work on tuning that out but the UCON is quite different from the GM ECUs I'm used to. Plus I'm told it adjusts for most things on its own. There's no VE table to adjust the sensed AFR to match commanded, so I don't even know where to start.
Anyway, this got longer than I wanted it to. Your experience/suggestions appreciated. G is busy enough as it is so I didn't want to bother him via email.
