SignUp Now!man i get jelly eveytime i check this thread lol...
meant to ask you, when you painted your wheels, you said you used anthracite.
was it the toyota supra color anthracite metallic (1a1) paint code?
Haha thanks! Im still having fun adding little bits here and there. Next phase is wheels but Im having a hard time deciding what I like.
Its actually just Plasti-dip spray can paint which is a spray rubber coating if you havnt used it before, so not an actual manufacturer paint code. I had to order the anthracite color as it wasnt in stores. I didnt want to do a permanent badass paint job on the factory wheels so dip is a good alternative as you dont have to sand at all and its really durable until you change tires and the edge gets torn. If you end up using dip make sure you clean the wheels and spray at least 4 coats. You want a thick material build so it can be peeled off clean, too thin and it just shreds. Ive done whole cars using a wagner type sprayer and buying it in gallons. The below link is just an example, you should be able to find it cheaper elsewhere.
https://www.amazon.com/Anthracite-Grey-colored-Plasti-Spray/dp/B00EKS5GDY/ref=sr_1_1?crid=3AQHUDUJN7XP&dchild=1&keywords=anthracite+plasti+dip&qid=1597923647&sprefix=anthracite+plasti,aps,195&sr=8-1
Nope. Just cranked all the way one direction. I searched and found something but they had helper bags.They may have shipped them at a good baseline already?
Option 1, WHOOP WHOOP!
opt 1 or 2 looks the best
glad your going with 19s because 18s always looked too small to me. since im not gonna drop mine anymore i may go with 20s.
Thanks! Got black lugs and stems coming. I might also blackout the inside barrel, think it looks better, especially when they start getting dirty. Then it will be tire time, going for a 40 series with mild stretchThat six-spoke setup is sick!
Great choice!
