X-roller
- Sep 6, 2008
- 5,448
- 2
So going from 3rd to 1st is what u want? Not really following cause if I'm in 2nd u want me to go to 3rd and then to 1st. Just too many extra moves but I'll yry it and get back to u.
So how does redline my-90 work better then Amsoil syn gear oil?
I can also shift thru all my gears with moderate accel and not use the clutch without any grinding. Just like how u would drive an 18 spd tractor.
Anyone else?
Since you said it's hard to get into first... is this from a stand still? or trying to downshift? if it's at a stand still put it into 3rd and then 1st.
And also with your 2nd gear issue when it locks you out... try going from 1st to 4th... Don't let the clutch out just throw it into 4th then 2nd.... same thing for the 1st gear issue. I know you have some mechanics behind you so i'm gonna ask you to check some stuff out on the shifter and links if you don't mind...
