Calling all transmission issues on Xrunner
Discussion in 'N/A Mods & Tuning' started by X-roller, Mar 9, 2010.
  1. thewarriordinghy
    Apr 9, 2015
    583
    11
    had it flushed last year?
  2. x-runner kid
    x-runner kid Active Member
    Oct 11, 2007
    1,346
    21
    Hmm seems odd. Maybe one of the auto trans guys could help I would try a thread on it and see what they say.
  3. thewarriordinghy
    Apr 9, 2015
    583
    11
    It doesn't bother me unless it's about to blow up....then I might need to do something
  4. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
    The delayed shift from 4th to 5th is of the norm. Some times it takes way too long. Doubld has also experience this in his auto. If I remember correctly the guy at level ten said the valve body upgrade will eliminate majority of the symptoms u described. Let me check my emails.
  5. thewarriordinghy
    Apr 9, 2015
    583
    11
    How hard is that install?
  6. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
    If you send in your unit, Not that hard. It's just messy cause trans fluid will drop all over your face. IPT has a video on their website of how to do the install. On the other hand if you do the DIY route with the level ten kit, I'm not sure how hard it is. By the looks of the other thread we spoke in, it looks fairly easy to do.
  7. thewarriordinghy
    Apr 9, 2015
    583
    11
    how expensive? I am trying to consider what all to do... not sure how much money ill have to mod, so trying to make a list
  8. Redlantern
    Redlantern Member
    Jan 28, 2013
    526
    6
  9. tcook08xrunner
    tcook08xrunner New Member
    Nov 16, 2015
    I have 08 xrunner with 120000 miles I've never had any grinding changing gears but when I shift from idle to first I get a clunk noice it's only from idle to 1st or reverse to 1st but never idle to reverse
  10. Hector Gonzalez
    Hector Gonzalez New Member
    Sep 9, 2020
    Hi all, Just did a clutch replacement, ordered clutch from the dealer did the install and replaced tranny fluid, have 2 new problems did not have before.
    #1. 3rd gear grind when shifting at high rpms ( feels like syncrho but wasent there before).
    #2 When riding in 2, 4, or 6. gear there is a hissing sound coming from the tranny right below the shifter, goes away when i disengage clutch,
    Any thoughts??
    I used factory fluid on tranny and had flywheel corrected.
    150k miles bone stock.........
  11. NHXRUNNER
    7,937
    279
    @o0opackersfano0o, any thoughts?
  12. mejbro
    mejbro Active Member
    Jul 11, 2016
    150
    50
    Welcome to the Underground Hector!
    Most of us have had better luck with MT-90 for fluid, but as long as you put 2 quarts of something Toyota in there you should be fine.
    Don't forget to adjust your clutch pedal, that may the reason for your hiss.
    There's a thread somewhere on here about it, also there may be a break-in period for your clutch so slow down lol
  13. Hector Gonzalez
    Sep 9, 2020
    Thanks mejbro looking forward to doing the MT-90
    Adjusting the pedal i seem to have too much top play. Hissing only happening in 2, 4, 6 though all the gears that happen to take the shifter down(not sure if this indicates something) what was once just a worn clutch is turning into a headache !!!!!
  14. Hector Gonzalez
    Sep 9, 2020
    So i just completed the oil change with redline i ordered from amazon.
    Let me just begin by saying im a BELIEVER now lol.
    Warmed it up did some cruising them ran 3 hard passes and what i noticed is the gears go in firm no clunks or clanks like before.
    3rd gear grind is GONE!!!!!!
    Im a happy camper now to break in the new clutch.
    Thanks fam much appreciated.
    NHXRUNNER, jimx and mejbro like this.
  15. NHXRUNNER
    7,937
    279
    I've run it in mine for nearly 200,000 miles. I'll never put anything else in it.
