SignUp Now!be careful when doing your camber, i bent one of my black tabs that come of the chassi. they are a little weak.:thumpdown:
i bent 8, yes 8!!!! when i mashed the brakes one time, flattened all the tabs, •XR•XR•XR•XRed my alignment, almost crashed me :hmmmm2:
i went and had my x aligned for the 3rd time in 4 weeks today and hopefully got it right, they called around to everyone local who sells the camber kits and no one even had a part number for 1, they said it wasnt avaliable.but i got my camber to -.07 on driverside and -.05 on passenger side.
That is within factory specs.i went and had my x aligned for the 3rd time in 4 weeks today and hopefully got it right, they called around to everyone local who sells the camber kits and no one even had a part number for 1, they said it wasnt avaliable.but i got my camber to -.07 on driverside and -.05 on passenger side.
Which drop kit do you have?i went and had my x aligned for the 3rd time in 4 weeks today and hopefully got it right, they called around to everyone local who sells the camber kits and no one even had a part number for 1, they said it wasnt avaliable.but i got my camber to -.07 on driverside and -.05 on passenger side.
You do not need any kit. factory specs are -1.4 to +1.4
I understand that, his camber may have been real bad before, but the numbers he just posted are 100% within factory specs, and WILL NOT wear tires at all.Hey Rob, you have got to see his tires, man. In less than 1000 miles they were in pretty bad shape. I was following him and watching him in the rear view a couple of weeks ago. you can definetly see the the top of the tires leaning. :argh:
It wont be long before he will have to invest in some new ones. $$$$$$
Which drop does he have I know its not C2C, im just curious what it is..
okay... this makes more sense...yeah its one of jons prototype kits,after my first alignment it was at -1.2 on driverside and -1.5 passenger side and had inside edge tire wear, then went back to the dealership and made them realign it, said everything was in factory spec another week went by and inside edge tire wear, yesterday rotated tires and went to the local firestone today and they got the specs to the -.7 driverside and -.05 passengerside and they reset the toe out an 1/8 of an inch they said this would fix my problem,so i only had to pay for 2 alignments and i am trying to get my money back on the first alignment i got becasue i got the lifetime alignment at firestone for 139.00.so i hope its right now and i hope with no more tire wear.:top:
