thecaptain0220
- Sep 7, 2010
- 124
I have been thinking about removing the capacitor in my truck but I'm not sure what all the wiring is doing. It would be nice if I could remove it and just connect some things under the seat without re-wiring everything. I am including some pictures of the wiring with a small description of the numbered spots. I am assuming the blue wires are positive and the gray are ground.
1.) This is a think positive wire coming from under the seat. Is this coming from the battery?
2.) This is a little thinner positive wire coming from under the seat connecting to a mystery box. Not sure where its coming from either.
3.) This is where the thinner positive wire connects to the mystery box.
4.) This is a thinner ground wire connecting to the mystery box.
5.) This is a thick ground wire connecting to the mystery box.
6 & 7.) This is where the thick positive wire connects to the fuse.
8.) This is where the thick positive wire connects to the capacitor.
9.) This is where a thinner positive wire connects to the capacitor. Not sure what this wire is for?
10.) This is where the thick ground wire connects to the capacitor.
11.) This is where the thinner ground wire comes from under the seat
12.) This is where the other thinner positive wire comes from under the seat. Not sure if this could be the some on from the other side? I figure its not and its running through something, possibly the amp?
I'm a little confused because of the thinner wires. I'm not sure what that mystery box is doing. That seems to be where the main ground comes from but I'm not sure why a ground an a positive go in and a ground comes out.
