Chopping front springs
Discussion in 'Suspension' started by Nashman, May 22, 2017.
  1. Nashman
    Nashman Active Member
    Oct 22, 2015
    425
    28
    Well i want my truck lower and handle better so
    i was debating about being cheap ass and cutting about 2 inhcs off my coils should lower is about 1 inc or so mix with flex form leafs
  2. NHXRUNNER
    7,899
    267
    One word.....NO
    x-runner kid and chatt x like this.
  3. Coupe
    Coupe Active Member
    Dec 31, 2007
    6,871
    15
    Dropped springs are pretty affordable. XII performance has done well by me.
  4. BSP06XRU
    BSP06XRU Old Member
    May 14, 2007
    12,964
    70
  5. NHXRUNNER
    7,899
    267
    What those two said ^^
  6. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    14
    Don't do it
    And cutting your springs will definitely not make your truck handle better. It will do just the opposite.
  7. SgtBadA
    SgtBadA Active Member
    Apr 21, 2013
    583
    33
    Oh man don't cut the spring. It's already pretty soft. Don't cheap out on this. You will regret it
  8. 30Birdy
    30Birdy Member
    May 3, 2015
    281
    21
    Put these lowering springs on it. PM if interested in purchasing
  9. bluXkid
    bluXkid Member
    Aug 30, 2015
    146
    I've been into lowering vehicles for almost 17 years. With that said, I've purchased lowering components and parts, cut coils, installed blocks, pulled leafs, bagged trucks and cars, built full suspensions on a couple trucks etc etc. I first want to say cutting factory coil springs isn't the best idea, however as long as it's not cutting them in half, it's not the worst thing you could do either. Whether it's cutting the stock coils or installing drop coils the amount of camber/toe is ONLY depending on how much it was lowered....not the method used. IE, if you cut a stock coil to lower the same 1.7" of a XII coil, the effects of the suspension are the same meaning the amount of toe/camber is the same. It will ride stiffer but that's about it.
    Long story short, mildly cutting a coil is ok. Don't expect it to absorb, rebound or ride like stock though. It will be rougher. The last thing you wanna do is heat up a coil.
    I would recommend a drop coil or SOS spacer though. Good luck.
    Keep in mind, stock coils are pigtail styled coil springs. They taper at the bottom. If you cut the tapered section off, you're left with a coil that will not sit correctly in the lower perch.
    #9 bluXkid, Jun 6, 2017
  10. o0opackersfano0o
    Jun 23, 2016
    439
    98
    just use spacers. cut coils if u want. its not the correct way but tons of people do it all the time. get some wide wheels and tires and she will handle on rails
    bluXkid likes this.
