clutch squeak returning
gunner76137
Gunner 05 Mine does it quite bad- think its just the tob though, it stops if you just barely press in on the clutch
TRDAntigua
double cab 09, 6Kmiles.. squeaking sound when releasing the clutch.. feels like its a rubber rubbing on something.. sprayed some silicone grease on it and it stopped for a bit.. but maybe WD40 might be better...
Good luck..
DannysBlkX
Danny 09 XR 7,500k comes and go's, really bad when it's hot outside.
thunder24685
mine has been fixed once and started again taking it in as soon as weather drys up to get it fixed again
dxrunner4me
I had the complete assembly replaced and 1 month to the day it was back. I only have 33k on an 07.
TitanRattler813
I've either gotten used to it or listen to my music too loud to hear it. I actually forgot that my clutch pedal squeaks :laugh:
nline4
as i learned from this forum, all you gotta do is look behind the pedal, turn the shafts just a little bit and the creek/squeak is gone. the shaft turns only so much from left to right and just keeping it in the middle will keep it quiet. i can do it by hand too. takes 5 seconds.
shaX 07
Is there a permanent solution for this? I am out of the 3/36 warranty but I was considering just buying all the parts that the TSB replaces, I think online I found them all for a total of around $230. But some are saying the dealer performed the TSB, but the squeak came back and i'm not gonna waste my money if this is the case.
I have tried the whole "turn the knob to the center" thing and this usually works great for a few miles, but then the thing turns on its own and goes back to squeaking like hell.
o5oldblue
never had mine fixed but it does it every now and then Shannon 05
TomsXR
The squeak comes and goes...When it comes it is really loud and annoying. Hate explaining to folks what the squeak is on a new truck.
hiflyer
yep, had it replaced 2x, then got the TSK ~ 110,000kms
kenneth206
Kenneth 2011 4,000 miles
Comes and goes and is pretty quiet...
FNMFER
2010, 21000miles.....all i did was rotate the shaft behind the pedal clockwise 1-2 turns and poof gone...it only happened twice and its prob been 4 months and still all g
MRBOJANGLES
I too have the clutch squeek problem. Very annoying! 2006 20k. Only on hot days though. Going to check it out today..:blurock:
Nola08xr
O8 with 43k.. I just keep clutch kickin till it go's away lol.
adamewwy
06 with 50K and have had squeak since 25K..has gotten a lot quieter since switching fluids over to Redline and Royal Purple it seems. Gonna deal with it until clutch goes out, lol
