Clutch Thread
Discussion in 'Stock Performance/Mechanical' started by gregincali, Dec 3, 2008.
  1. XRangel
    XRangel New Member
    Sep 5, 2008
    242
    I could shift into gear however it just accelerates goes nowhere
  2. Grumpy
    Grumpy New Member
    Jun 16, 2007
    5,051
    ^^ Clutch disc is separated. The center and outer friction material is longer together.
  3. larojax-r
    larojax-r Member
    Jun 15, 2007
    56
    throw out bearing replaced under powertrain warr at 39k, just picked it up today, no charge...
  4. HolyCow
    HolyCow New Member
    Dec 24, 2007
    24
    larojax, what were the symptoms on your bad throwout bearing. I'm having a heavy vibration sometimes when releasing the clutch during first or reverse. After I'm in gear, it seems to go away. Other times its fine... Looks like I'll be going to the dealer soon...:hmmmm2:
  5. Devildragon
    Devildragon New Member
    Jan 23, 2007
    34
    42,000 miles still no problems(knock on wood)
  6. xrunner224
    xrunner224 New Member
    Apr 8, 2009
    566
    ok i got a question
    when i push in my clutch and let it out it squeeks, would that be that it just needs greese,
    not sure if its andthing but just checking
  7. TitanRattler813
    Feb 28, 2007
    7,656
    33
    This month, I noticed an intermittent chirp. The throwout bearing is on it's way to hell again. Luckily no idle squeal, but occasionally I hear it spinning around in there when I shift. *fingers crossed* I have 6k left on my bumper to bumper. Powertrain is a little tougher of a battle, so I'm hoping if it does, it goes before 36k
  8. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Well, the inevitable has happened. I drove over to my storage unit, left the truck running, went inside, came back out and there it was. The idle squeal has returned :frown:
    Sucks even worse b/c I don't have time to take it back to Toyota before I move this coming week.
    FML... and whoever designed these crap transmissions and throwout bearings :thumpdown:
  9. holddeez08RR
    holddeez08RR New Member
    Oct 4, 2008
    990
    Disc seperated at 14000. Clutch and t/o bearing replaced under warranty
    New clutch has interesting chatter and t/o bearing squeals like a horny pig :biggrin:
  10. evilk401
    evilk401 New Member
    Mar 5, 2008
    41
    wats the best clutch kit
  11. Black-X
    Black-X New Member
    Feb 29, 2008
    337
    I've got an '08 with about 13-14k miles, and i've noticed a squeel at idle. At first I thought it was one of the pulleys, but when I checked under the hood, the noise was coming from under the truck. It sounded like it was coming from the transmission. When I push the clutch in just a little, it goes away. I'm suspecting it's the throw-out bearing, so guess I gotta take it in soon.
  12. RedXr
    RedXr New Member
    Jan 4, 2008
    2,744
    Right now we have 3 available. Paradise, Competition Clutch, and Spec.
    Although I have heard no reviews of the product, the Spec clutches seem to be a good choice (solely based on product specs). Best thing to do is contact these vendors on the site and let them know what your goals are, they can hook you up.
  13. JJ LaMay
    JJ LaMay New Member
    Mar 21, 2008
    27
    i ripped out the center of my 08's clutch about 2 months/2,000 miles after i bought it brand new. the dealer fixed that one under warranty. then two months later at 4,500 miles it ripped out the center again. said it was b/c excess heat, strain, heavy load on trans, they said i was hauling somthing too. my truck hasn't ever hauled anything but my fat a$$. they made me fix for $4000, but i took the this one home me. now it seems like its going to do it again. i have babied this truck since the day i got it . i had a TC that i pounded the he!! out of for 70,000 mile and didnt have one problem out of. and i have talked to other 08 owners that had the same issue. hit me up in a private messege if u got a comment
  14. SX TOY
    SX TOY Active Member
    May 23, 2009
    1,965
    mine started doing the exact same thing yesterday. I too thought it was a belt till I heard it go away with the clutch depressed in or out of gear.'08 with 12,760 mi :thumpdown:
  15. ACE OF SPADE X
    ACE OF SPADE X New Member
    Jul 24, 2008
    1,289
    ok this is my first manual so is it normal to be able to hear my clutch go in and out of gear pretty good ? and when is a good time to get a new one , i have about 50k?
  16. SX TOY
    May 23, 2009
    1,965
    these trucks "talk to you" more than most manuals do so that is normal.you will feel when it is time to do your clutch. it will take more rpms to get moving( because of the slipping disc) I have had clutches last 100k but we have issues with the stock clutch design and many go out well before that.
  17. varney31
    varney31 New Member
    Oct 19, 2009
    32
    2009 xrunner at 9000 miles i busted the clutch in the middle but it got replaced under warnnty
  18. SX TOY
    May 23, 2009
    1,965
    I took my truck in for its normal service and told the service tech I had a squeak that went away when I pressed the clutch in and an occasional grind in second at high rpms. they checked it out and had a new tranny ordered before I left. I ordered a stage 3 clutch and lightened steel flywheel from the G man(thanks) they are going to put in free on sat with my new tranny. I am also going to pick up some redline tranny fluid to have them put in.:top:
  19. TitanRattler813
    Feb 28, 2007
    7,656
    33
    yessss... on my way to the dealer right NOW
  20. SX TOY
    May 23, 2009
    1,965
    good luck bro:rock: that squeak is pretty annoying :ahhhhh:
