Clutch Thread
Discussion in 'Stock Performance/Mechanical' started by gregincali, Dec 3, 2008.
  1. holddeez08RR
    holddeez08RR New Member
    Oct 4, 2008
    990
    Second time having clutch replaced, the forks on the pressure plate were bent. They replaced clutch, t/o, pressure plate, and resurfaced the flywheel. 20k miles. I was told to take it easy on the new one :smile:
  2. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Question for those warrantied
    For those who got the warranty stuff done, what was the series of events? Especially those of you with aftermarket stuff installed...
    I have an appointment for tomorrow morning to the service department. I already know they are going to hear the squeal then do what they do. But...
    I need to get my hands on a stock clutch (already have my old pressure plate and flywheel).
    Do they typically diagnose first, then if I need to, schedule a follow-up for the actual service? or will they already have my truck disassembled, tell me it's covered and start working right away?
    If it's the latter, I'll just order a clutch first before I even take it in.
  3. TRD-X
    TRD-X Active Member
    Aug 30, 2009
    3,692
    Ok the dealer had to replace the clutch pedal mount on my X ,so they didn't give me a hard time. The nosie problem from pedal was a bolt and shim no put on at the factory. So had other problems that helped me. I don't know if you had this problem or not but if you did then this will help you get the clutch replaced!:top:
  4. Tunedx
    Tunedx Active Member
    Dec 23, 2007
    3,084
    Anyone having warranty cover repairs are u removing performance parts before this is doubt with?
  5. SX TOY
    SX TOY Active Member
    May 23, 2009
    1,965
    they use a stethoscope to ascertain where the squeak is coming from. the guy told me if it goes away when you press the clutch pedal in it is the tranny or input shaft. if it only squeals with the pedal depressed it is the t.o. bearing. I pmed you with more info
    I left on my b&m for the diagnosis. they are swapping it, installing a stage three clutch, lt flywheel and redline with the new tranny.
    #65 SX TOY, Nov 20, 2009
  6. TitanRattler813
    Feb 28, 2007
    7,656
    33
    I could've told them that, lol. I don't understand why they want to keep my truck all day :hmmmm2: They said I HAVE to drop it off and leave it. I've been through this once before.
    Ah well, as long as it doesn't cost me any money I'll do what the folks say
  7. SX TOY
    May 23, 2009
    1,965
    that is odd I waited about two hours but that is including an oil change and tire rotation. best of luck bro
  8. TitanRattler813
    Feb 28, 2007
    7,656
    33
    I saw why they said that this morning. Saturday is service day. I got there at 7am and the service line was jam-packed. They drove my truck around to the side. I guess that's where the real techs work, rather than the oil-change/tune-up chronies. I was there an hour or so then had a ride come pick me up so I can go back to sleep
    UPDATE: *Swear Words!!!*
    Service guy says that ONCE AGAIN they are just going to change the throwout bearing. They aren't in the same region as Avondale Toyota so they have no idea that this is my 3rd time aside from me telling them so. I went back with my paperwork but everybody was on their way out to lunch. Supposedly ALL the parts were ordered, so when I go back the Tues after Thanksgiving, we'll see what this dialogue turns into...
    #68 TitanRattler813, Nov 21, 2009
  9. DustyXRunner
    DustyXRunner New Member
    Jul 26, 2009
    672
    just had my truck towed to my work. was drifting in first and shifted to second and when i let the clutch engaged it popped. would go into gear fine but clutch would not engage. i am pretty hard on the truck. im not surprised. 20,995 miles.
  10. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Update... I took my truck back in today. They say they will not cover ANYTHING because I have the Competition clutch kit installed. Grand total, including bell housing $1800.00+
    I told them to make a call higher up and get back to me later on.
    If I have to pay out of pocket to fix this shit, my truck and all parts will be for sale immediately after.
    Please advise....
  11. shaX 07
    shaX 07 Active Member
    Mar 2, 2008
    2,102
    I too have clutch pedal squeek and I had my TO replaced under warranty around 35k miles :top:
    Can't you just put the stock clutch back in and take it to a different dealer and have them fix the TO?
    #71 shaX 07, Dec 1, 2009
  12. NHXRUNNER
    7,947
    283
    Exactly what I would do :top:
  13. TitanRattler813
    Feb 28, 2007
    7,656
    33
    That means I need to get my hands on a stock clutch assembly... meaning I need to pay SX TOY a visit. Fvck I hate Toyota at times like this.
    They're still gonna shaft me for 5 hrs of labor either way
    FYI, my truck is sitting at the dealership up on the lift with the transmission, flywheel, and clutch on the floor.
  14. NHXRUNNER
    7,947
    283
    BLAH :puke: The problems you've had would drive me to punch babies :thumpdown:
  15. shaX 07
    Mar 2, 2008
    2,102
    I knew it! I knew you were part of a baby punching cult :D
  16. TitanRattler813
    Feb 28, 2007
    7,656
    33
    Well... no dice. They won't budge. (Not-so) funny thing is, I just called my service guy in AZ and he said they would've covered it no question.
    Oh well... I'll have some stuff up for sale within the next day or 2.
    Question... if I tell Toyota to eff themselves and give me my truck back (since I didn't authorize any actual work) how much money can they charge me? (although the tranny is already down and apart)
    #76 TitanRattler813, Dec 1, 2009
  17. SX TOY
    May 23, 2009
    1,965
    I am not sure but I would try telling them that you can't afford it and you want your truck back.
    then take it to another dealer we have plenty in sfl
  18. TitanRattler813
    Feb 28, 2007
    7,656
    33
    That's my plan. I'm about to call them right now. I went through this crap in AZ too until I found out about Cejay at Avondale Toyota, thanks to Beau and Bryan. I just spoke to the service manager over there and he himself told my that this situation I'm in is bullshit but he can't do anything about it b/c I'm not there to bring my truck over.
  19. blastap
    blastap New Member
    May 20, 2007
    4,247
    If you did not authorize the work then they really cant take it apart. I have a stock clutch with pressure plate and flywheel if you need it. Its in great shape.
  20. teamben158
    teamben158 New Member
    Oct 6, 2009
    404
    I've read a bunch of threads on this site regarding this clutch issue and now I'm starting to get worried.
    I have an 08 with 13000 miles on it and lately I've been noticing a creek/squeak when I press/depress the clutch. It's also been getting a little more difficult going into to gear, especially second.
    Does this sound like the dreaded bearing issue?
