Clutch Thread
Discussion in 'Stock Performance/Mechanical' started by gregincali, Dec 3, 2008.
  1. 05 X
    05 X New Member
    Jan 4, 2008
    165
    Lost second clutch last night during a nice easy drive to the grocery store. Luckily, it was on the was back and I could coast into the neighborhood. Last little hill needed a push by 2 of us to get up and then I could coast into the driveway. Guess I'll be getting it towed to the dealer on Monday.
    I'm at 63,000 miles, but I have the extended warranty. The last clutch to go happened before the TSB was released, so corporate only gave 1/2 back after the TSB was released and said if it happens again they will give back the other 1/2. I still need the dealer to verify this time it has the same problems associated with the TSB. More to follow...
  2. 05 X
    05 X New Member
    Jan 4, 2008
    165
    Two weeks later and the TSB did not apply and extended warranty did not apply. I now have the Stage 3+, URD Lightweight Flywheel, and URD TSK45.
  3. Xtacy
    Xtacy New Member
    May 29, 2008
    1,380
    ^ I ordered the exact same thing, have yet to get it in. How do you like the set up?
  4. 05 X
    05 X New Member
    Jan 4, 2008
    165
    So far so good. I'm driving real easy the first 500 miles. With the lighter flywheel, the RPMs go up quicker, but it seems to grab better. After next week I'll be commuting to DC regularly and should get a better feel for it.
    I posted on another page about T/O bearing that comes with the SPEC 3+; even if you use the TSK45, check the height of the SPEC supplied bearing vs the stock one that is in your truck now. It appears SPEC is packaging the wrong size. Also, I changed the white plastic gromet at the bottom of the shift arm because it was half worn.
    Let us know how yours turns out.
    #124 05 X, Aug 13, 2011
  5. Torspd
    51
    What was it you had said in the other thread? That they were shipping out the throwout bearing for an FJ right? Or something like that?
  6. 05 X
    05 X New Member
    Jan 4, 2008
    165
    The guy at SPEC said the T/O bearings for the FJ and Tacoma are the same exact size because they use the same engine - so they only pack the one size in the kit. The bearing they sent me is 1/8 inch shorter. I'm hearing from reliable sources that the FJ bearing is 1/8 inch shorter too. I haven't called them back because my truck was put back together late on Friday with the TSK45 and I wanted to be sure there was no other problem - I'll call Monday.
  7. STONER-X
    STONER-X Active Member
    May 15, 2008
    3,372
    yall will love it... i got about 30k on that set up... if you can look past the cattery flywheel its great!! the chatter to me was a little "uneasy sounding" at first even though it is totally normal.... once you learn to shift past the point of chatter you will love it!!
  8. justin13703
    justin13703 Active Member
    Sep 9, 2010
    2,766
    14
    Yeah I have that same setup and the chatter is kind of annoying at first but you get used to it and it makes up for it the way those suckers grab
  9. adamewwy
    adamewwy New Member
    Aug 2, 2011
    448
    yeah they are pretty loud, makes you almost think something might be wrong, but they do grab hard
  10. brownbrown
    brownbrown New Member
    Sep 28, 2011
    132
    Just picked up My X-r a week ago... Noticed a squeel at Idle too. Thing only has 31k on it :-(
    It's Toyota Certified so it's going in the shop already. less than 2 weeks of ownership :-(
  11. J_StradaXR
    J_StradaXR Banned
    Jul 11, 2010
    1,727
    T/O bearing
  12. brownbrown
    Sep 28, 2011
    132
    Had no clue before the forum. Thanks Strada and all the other contributors to the thread. :blurock:
  13. brownbrown
    Sep 28, 2011
    132
    Fixed under warranty no problems, Rep tried to tell me it could be a belt. I told him it was the T/O.
  14. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    a belt? lmfao what a idiot. the squeal with the t/o bearing is gonna come back for some reason the way they either designed the t/o bearing or the input shaft it creates heat right there and allows for the squeak i have greased my input shaft sprayed it with white lithium there is just no fix for it so i say poor design
  15. turbomach1
    turbomach1 Member
    Feb 13, 2012
    209
    I just bought a 07 x-r. Notice the clutch was slipping on the test drive. So I got a good deal on it. Order urd flywheel and stage 2 clutch before finding this. Glad I made the right call On that. Toyota should be ashamed of this. Lean manufracting stricks again.
  16. donovanbedwell
    donovanbedwell New Member
    Jul 6, 2012
    300
    throwout bearing! it completely embarrasses me when i pull up somewhere and it starts squeaking. is there any way to fix the problem without replacing the throwout bearing itself?
  17. TommyXrunner
    TommyXrunner New Member
    May 22, 2012
    1,859
    wow! this thread is a nightmare to read :ahhhhh: i get a scratching noise when i shift from 1st to 2nd at low rpms and it grinds going into 5th a little when reving high. i'm wondering if changing the tranny oil to amsoil will help my clutch and tranny last a little longer
  18. Can XR
    Can XR New Member
    May 23, 2011
    277
    From what I have read and been told the only way is to replace it. Mine is screaming right now. My stage III, flywheel and TOB should be here this week. Got them all from URD
  19. X-MOKED U
    X-MOKED U New Member
    Sep 14, 2012
    1,228
    bought the truck 2 months ago, 35,205 miles, cluth went out at 35,500 i assume the first owner had no clue on how to drive since the low mileage delaer i bought it from gave me 30 day 1000k guarantee so it was no problem
    got a freshh cluth on my truck and it feels great!
    *been having an annoying squeak coming from my cluth pedal idk if thats commmon or what? :hmmmm2:
  20. justin13703
    Sep 9, 2010
    2,766
    14
    Yeah, real common and real annoying. Lol
