Code p2241
Discussion in 'Stock Performance/Mechanical' started by Xrunnerbjt, Sep 4, 2013.
  1. Xrunnerbjt
    Xrunnerbjt New Member
    Jul 5, 2007
    596
    Just got this code after the start up and I know it has something to do with the o2 sensors. Just installed the mk3 and hopefully just getting the bugs worked out. I don't wanna have to buy a new o2 sensor. I know they are expensive. Is that right though? What are the remedies for this one? I've lit this forum up over this boost, but just want everything to be right
  2. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    Bank2 sensor1
    It's saying the sensor in the drivers side header is no good, double check the connection, IMO that one is easier from the bottom unless you have really small hands...
    And yeah they aren't cheap but can be had around $125...
    #2 hottacoX, Sep 4, 2013
  3. Xrunnerbjt
    Jul 5, 2007
    596
    What caused it to happen? S/c?
  4. hottacoX
    hottacoX Moderator
    Dec 21, 2009
    4,823
    Couldn't tell ya the cause if its bad, but didn't you just have your headers out? If I recall you were trying to get the collector bung out?
    Anyway either it went bad as they are a wear n tear item or it wasn't fully clicked in and has come out...
  5. Xrunnerbjt
    Jul 5, 2007
    596
    I didn't have my headers out, just tried to pull the bung out. But it didn't budge, and i drove 100 miles yesterday and it never came on. But what will that do? Will the ucon take care of it?
  6. butters607
    butters607 Active Member
    Oct 3, 2009
    3,826
    Don't not replace those if they are bad.....
  7. Xrunnerbjt
    Jul 5, 2007
    596
    Do not replace?
  8. butters607
    Oct 3, 2009
    3,826
    Ok if it's bad don't let it stay in there bad and drive around like that.
  9. Torspd
    47
    What do you mean that you tried to pull the bung out?
    Did you loosen or tighten the factory AFR sensors (sensors in the headers)? Did you mess with their plugs?
    If you did, check your connections.
  10. Xrunnerbjt
    Jul 5, 2007
    596
    On the jba headers, there is the extra hole where you have a bung plug to go into, where you can plug it, or put a wide band in. I didn't have a wideband at the time and now that I do, I tried to remove the bung and it was stripped so I couldn't get it out. I didn't touch the other o2 sensors since I installed my headers about 10 months ago. Never had a problem until I put the supercharger on
  11. Torspd
    47
    Oh. Ok.
    Next plan of action, if you have a UCON, call URD tech support.
  12. Gadget
    10,871
    126
    Why start now....
    Anyway, if you have a URD Supercharger system the front O2 sensors should be installed in the collector with the extension harnesses and not in the upper port in the center tube. Needs to sample all the cylinders on each side of the engine.
  13. Xrunnerbjt
    Jul 5, 2007
    596
    So it doesn't go in the header at all?
  14. Slywhitty
    Slywhitty "Midget Magnet"
    Jan 26, 2008
    3,389
    The sensors will go where you wanted to install your wide band. But you need the extensions to do it. Then your wide band will have to be installed elsewhere
  15. Xrunnerbjt
    Jul 5, 2007
    596
    Or just goes to the back holes on the header? Because that goes back to the problem of me having the bung plug stripped and can't get it out.
    Ok, I see.
    #15 Xrunnerbjt, Sep 4, 2013
  16. Slywhitty
    Jan 26, 2008
    3,389
    Get yourself that ez out and have at er lol
  17. Xrunnerbjt
    Jul 5, 2007
    596
    Where can I get the extensions?
  18. Slywhitty
    Jan 26, 2008
    3,389
  19. Xrunnerbjt
    Jul 5, 2007
    596
    How safe is it to run them where they are right now should I ask. I gotta save some money lol. Dropping the money for the Urd kit broke me about.
  20. dramad1
    dramad1 Active Member
    Mar 27, 2010
    2,367
    Just know that you are only reading banks 3&4 and not all six, so if your running rich or lean/ you'd never really know. Could be a recipe for boom, being f/I and not knowing your afr's.
